noise from cd player connected to another amp, why?
Mantra
Europe
Hi
I have in a row , a cambrige , rotel , marantz and denon
a marantz cd signature is connected to my marantz amp , with good cable
but my marantz amp is off and my marantz cd player is playing a cd , i can hear some noise/music on my denon and other amps (when they are on)
as soon i stop my marantz siganture cd player , this noise/music ,is noise mixed with music disapeard
it' s very strange , should i buy double shielding like KabelDirekt , europe amazon
have you notice some issues?
thanks
Hi
thanks
Can you clarify what I’ve highlighted in bold? What are these devices and how are they connected to each other?
If your Marantz CD player is connected to your Marantz amp, why are you playing music with the amp turned off? Some context is needed.
Hi
i have a cambrige on top , under a rotel , under a marantz and under a denon , in short one on top of the other
about the marantz cd player is connected to marantz amp , but my marantz amp is off and i have used headphones
maybe i have to buy should i buy double shielding rca cables , i use good normal rca cables not shielded
thanks
Deutsch? Wie sind die Geräte untereinander verbunden?
Genauer: Sind die Verstärker miteinander verbunden?
Having the components on top of each other may be a large part of the problem.
hi
are you sure?
have you your components on different places?
thanks
1 <IMG> is worth a thousand words.
My hunch says it's some sort of ground loop, but without knowing what the devices are and how exactly they're connected it's near impossible to pinpoint the problem.
Sounds like crosstalk but between different amps?
hi
could be the cables?
thanks
hi
thanks
Again we still need some context.
What are the components? Listing brand names doesn’t tell us what anythung is. Are they amps, CD players, DACs? What is connected to what? How they are stacked shouldn’t be relevant other than for ventilation depending what these components are.
You need to provide info on how you have these units connected and what they actually are.
Components power transformers can create fields that can be picked up by other components sensitive inputs or by poorly shielded interconnect cables.
Hi
I have avoided many time shield cables ,and i have often bought 99% copper without shield just because several friends told me they do sound better
do you think many shield cables on amzon are pretty great?
thanks
sorry for my poor english
Take some pictures of the connected components (rear panels/wiring). Make it clear what is connected to what and what specifically the issue is.
Many coax cables on Amazon don't have great shields.
Look for cables with a heavy braided shield.
Like the:
Canare LV-77S
Belden 1505F & 1695A
Blue Jeans Cable LC-1 & LC-2
