New SMSL M500
mkawa
yah, mine goes magenta. firmware version is 1.4. hardware version is 1.2
from the manual text it sounds like purple or green indicate MQA streams (ie, tidal) and blue indicates an MQA file (purchased MQA?)
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
I could send him mine if he hasn't gotten any more local volunteers.
I'm Mid Atlantic.
mkawa
blue, green and magenta all seem to indicate that MQA is being fully decompressed in hardware by the dac. i think you're fine.
armani006
I never seen magenta light, only green or blue. Some Master tracks shows 352.8kHz rate.
I'm Mid Atlantic.
It will be awesome, I'm waiting for measurements ))
Jaysz
Anyone using tidal
What sampling rate does dac show when switch of exclusive mode
armani006
Anyone using tidal
It depends on track quality, Master tracks show up to 352,8 kHz, sometimes 192, HiFi shows 96 and 44,1kHz as normal
Jaysz
Even if i listen to a non mqa 44.1khz track the dac display jumps up to 352 khz when switch of exclusive mode in tidal
Has anyone else tried this
Patrick1958
Belgium
Is you sampling rate in soundmanager (windows) set to 352 kHz?
mkawa
are you using the smsl windows driver?
fyi, i'm running pseudo balanced, as the m500 has a floating ground and so does my amp. xlrs and rcas are always powered in preamp mode.
Jaysz
Yes download for driver is from smsl its xmos
Tracks at 24 192 from qobuz shows ok
