artishard116
- Joined
- Sep 6, 2021
- Messages
- 54
- Likes
- 51
Wondering if you run it like this all the time? Would cut down on cables/splitters. Basically source feeding analog xlr to one sub and then a coax bnc connecting that sub output to the input of the second sub. I'm testing it now but the sub and speaker getting the signal over BNC seem noticeable quieter than the sub and speaker being fed the analog signal. Haven't run an alignment yet, but maybe that would match the levels?If you use Input Mode Automatic you can connect the second sub via BNC and use XLR for the rest of the setup. You can also connect both subs via BNC and only the sats via XLR. It doesn't matter which sub which sat is connected to as long as both subs get the identical signal on both (L&R) inputs.
