new KEF KC62 dual 6.5" subwoofer
AdamG
Don’t let others steal your joy and happiness.
Moderator
Reality
FYI there is no such thing as faster or slower subs. They play at exactly the same speed, also known as Frequency or cycles. Some go lower and some go higher in Frequency at a given SPL.
Chrispy
PNW
what
yes - actual measurements are missing - something i am desparately waiting for. Note that i like the svs features and looks better than Kef’s, but in the end the deciding factor is how they will match my LS50w2’s... ie sound quality in combination with the la50s
Any sub can match up with your speakers....it's mostly a matter of integration on your part.
prmfeddema
I guess with sufficient tuning it could - but i keep wondering what the impact of new technology is in these cases? I don’t like Kefs (deceptive?) marketing of the kc62, but kef engineers are not idiots ( and neither are SVS’s engineers) but there are also other aspects relevant to me (and which vary from person to person) which may actually lead to select a sub with a less than perfect sound but with other features (size, color, no dangling cables) - basically it is the eternal struggle between the tech in me and aestetics...
Chrispy
PNW
I guess with sufficient tuning it could - but i keep wondering what the impact of new technology is in these cases? I don’t like Kefs (deceptive?) marketing of the kc62, but kef engineers are not idiots ( and neither are SVS’s engineers) but also other aspects that are relevant to me (and which vary from person to person).
Tuning? Is that what you call integration? Engineers may not be idiots but probably aren't allowed to say much, that's usually the marketing department's turf. :)
prmfeddema
Ha - tuning/integration... a number of any (technical as well as non-technical) activities to arrive at an optimal result :)
guess we are on the same page :)
Chrispy
PNW
Tuning a sub to me is when you're figuring out the tuning point for a ported sub :)
Martin
Cape Coral, FL
And pretty decent measured in room response:
Here's some measurements with KC62's near rear corners, using UMIK-1 mic.
GREY=PMC 25.23 speakers ; BLACK=one sub; BLUE = both subs; RED = too loud for me!
twin_kc62_measurements-png.1475387
Martin
AdamG
Moderator
Reality
Martin
Unless I missed it, without knowing the size of the room, the measurements are of a questionable value. I bet an IPhone can measure well in a mailbox.:rolleyes:
YSC
well, I assume if you want to use such an expensive yet tiny sub, you will not be in a large or medium sized room;)
Just as I expect smart for 2 buyers won't be weighting 200kg (there are always exceptions of course)
oursmagenta
France
Martin
Well, not bad !
Here is my super-imperfect (have to tweek the Dirac calibration) in-room response with a target resembling to an harmanish one.
My sub, a SB-3000 is much, much larger ! The room is roughly 2161.3 cubic feet (22.31x9.84x9.84) or 61.2 m3 (6.8x3x3), the crossover is at 120hz (I have some Triangle Cometes bookshelves).
N.B: I edited the post and quickly re-did measurements.
YSC
Well, not bad !
looked nice, you are using a single sub? and if so at 120hz did you encounter some localization problem for that?? (assume you are not using a single sub from behind, which personally I did perceive that bass is from the back..)
oursmagenta
France
Yes, a single sub that seat to the right of my left speaker. For localization, hmm no it doesn't seem an issue for me.
onion
Does anyone know of good research on the localizability of bass notes and why the 80Hz crossover was chosen by THX?
I remember (years ago) reading that it was selected because it was an octave lower than the lowest test tone any subject was able to localize, at 160Hz. I also remember reading that no one else was really able to localize below 200Hz.
This is all coming from memory, though, and I have no idea where I read it or how to search for it again. I would think multiple subs would be even harder to localize. These subs are tiny enough to easily hide around the room. I'm imagining a scenario with 4 of these hidden around the room and crossed at 180-200Hz(with steep filters). It seems like that could potentially fix the Meta's only real weakness(imo), turning them into an end game speaker that's still rather aesthetic. Personally, I'd still go for larger subs, but my mom despises the look of visible giant subwoofers. She loves the sound of my RS2s, but hates the appearance. Something like this may the Goldilocks solution.
I don't know of any research but I've played around with crossovers in a 4-sub setup. I can't localise at 250Hz. So I'm playing around with the crossover range from 250 to 80Hz to see which one gives the best integration of mains to subs.
Chrispy
PNW
Keep in mind the upper frequency limit of your sub.....and a crossover still yields content above the crossover, too....
