new KEF KC62 dual 6.5" subwoofer
No measurements i'am afraid.
In that case that should be your first priority. Get yourself a cheap UMIK-1 calibrated measurement microphone, install REW on your computer, and start measuring. Subwoofer integration without measurement is next to impossibe. Measurement is also the basis for dsp room equalization, which is another thing that you cannot do without if you are using subwoofers.
Oke thanks for the advice. I will have to familiarize myself with that software and what those measurements actually mean
I've had a weird problem with one of my KC62s where it sounds like it's having random pops of random volume. In-room it sounds like my neighbor is thumping the wall, and occasionally it seems to go to full volume, sounds like they slammed a heavy door next door. This only happens with one of them. They're both on the wireless adapter. The one experiencing the pops is furthest from the transmitter (about 20ft) and it's also sitting next to a Wifi router, so at this point I am not sure if it's defective or if it's interference. Anyone experienced anything similar?
I'd rather not send this hefty little brick back, but obviously I can't live with a sub that adds bonus thumps to whatever I'm listening to.
Try to switch places between the two subs?
@MattHooper might enjoy them.
"... next to a Wifi router ...." That would be my guess, at least try to eliminate the possibility. Way back I had a problem with a DAC (Auralic Altair) popping, which exhibited pops, when WiFI was on / close.
So I switched the popping one to the other location and the popping seems to have stopped. I'll try it another day or two but at this point it seems like it was probably the router. I'm surprised in that I haven't had that kind of interference in a very long time, maybe ever... not surprised, in that I was running a wireless audio adapter about 4" from an active wifi mesh router.
Anyway, if anyone is wondering whether these units can (measurements aside) make loud noises, the answer is yes. Everyone was fully convinced something big and heavy had hit our wall the first time we got a full scale pop out of the thing.
New member here, long time lurker, amazing forum. I have a KC62 and I'm wondering if anyone has an opinion on the quality of the KC62's digital crossover? In general I try to maintain the most direct signal path possible, but using the KC62 in the 'small room configuration' (using a preamp and power amp) requires me to run everything through the KC62's digital crossover and then forward the high pass frequencies to the power amp and main speakers (KEF LS5 Metas). Given that much of my system is analog (phone / tube pre amp / tube main amp), it feels like throwing a DSP in the middle of it all is not optimal, though this configuration does have the very great advantage of removing the low frequency energy from being passed on to the power amp / main speakers. My ears suggest the DSP is quite transparent, but I'm tempted to design my own analog crossover network in front of the sub to fully eliminate the internal DSP. Informed opinions welcome.
I had a discussion with KEF about this same issue several years back. They confirmed that the pass through signal goes through DAC, DSP, and ADC stages (not necessarily in that order), and then THAT signal goes on to your mains system with whatever additional processing downstream. I thought this was a bit ridiculous and so I opted for a miniDSP SHD which handles everything in one place quite admirably (and also Dirac Live room correction). SHD replaced my prior DAC as well. Years later and I’m still very happy with my system.
I used to use the "speaker input" as I was told by some internet reviewers that that was the best. But since then I switched to line and I don't use the crossover. I have a room eq. in my preamp and it shows a smooth transition from 20 to 200
Just to clarify, did you use the low-pass filter on the KC62? If so, what frequency is it set to? With the LS50 Meta loudspeakers, running them full-range and then blending in the subwoofer's low-pass filtered output is entirely possible.
You really can’t expect much from a subwoofer’s onboard ADC-DSP-DAC and hardly anyone ever tests that, but the real problem is that you’re taking time alignment of the sub totally out of the equation with this setup. Can’t you insert a miniDPS 2x4HD into the chain to preserve the signal and do some proper time alignment? Worth the price of admission to achieve both results, in my book.
The crossover is in my pre-amp (at 80Hz) but in the past, I did try the full range RCA line input as well as speaker input with the KEF crossover. Too many wires.
@Dennis_FL Do you know the order and type of high-pass filter that is used in your preamp (the Wiim Ultra)? And what is the setting on the low-pass filter in the KC62 subwoofer and the setting of the polarity switch? Some simple modelling does seem to indicate that it's quite possible to get a very good blending between the two sets of outputs. Interestingly, the ASR measurements of the LS50 Meta indicate a 5th-order low-frequency roll-off rate below the low-frequency knee, rather than the 4th-order roll-off rate that a vented-box enclosure might be expected to have.
^^^Not a chance that little box with 6.5 drivers is hitting 11hz unless that’s the sound it makes as you drive over it with a truck^^^. More meaningless spec claims.
It might do that, but it won't be loud there. You can't send a six inch woofer out to do a man's job.
I heard it once, at about an in-room SPL of 60db. ;)
I haven't a clue. But the 20Hz to 20K response is a flat line after I did a room correction. It was pretty flat before the correction. You want to bring the crossover to a point where the sub falloff and the mains falloff intersect like # 1 in the picture.
I did some simulations in VituixCAD involving an approximation to the LS50 Meta's low-frequency response and those of a subwoofer's response. These seem to indicate that the overall combination is relatively insensitive to the types and order of the typical low-pass and high-pass filters that might be used.
