EJ3
Since we now know who is behind it, I'll give it a strong (leaning to the "YES! side) MAYBE (but still a wee bit skeptical).Hmmmm...![]()
I see it as pure marketing. Yes, they exist but real world performance is closer to 22-23 bit for the best stuff. More than enough.So science indicates audio benefits from 28 bits? Aren't there already 32/768 DACs out there anyhow?
By this measure, the Topping D30pro is a 128-bit DAC thenSchiit has a 64bit dac
So do I - if it is actually achieved at the DAC output.I do have to admire the engineering making such performance possible, though.
No. The effective noise impedance is the parallel combination of input and output impedances, thus dominated by the latter.The first thing that signal is going to hit is the input impedance of the pre-amp or amp - typically 10K and up. The thermal noise alone coming from that input impedance (let alone everything else) is going to be around 40dB (100x) bigger than the output noise of the DAC.
+28dBu output is 19.5V that's +19.8dB opposite 2V for the S/N ratio when assuming lowest possible noise.Assuming a 2V FS, then the LSB is about 7.5nV (0.0075 microvolts)
Thermal noise on that 10K resistor mentioned up there ^ is around 1.8uV at room temperature. Some 240 times bigger.
Yes. A 27-bit DAC should be demo'ed at the 2023 AES Conference, Oct 25. That's a noise floor of -145dBu (broadband, unweighted) and a maximum output of +22dBu. A 28-bit option will be available for professional applications (+28dBu max output). Shipping 2024. New company is called "imersiv"
Good point - so the output impedance of the DAC (including PCB trace, wire and connector) needs to be of the order of that 0.17 ohms mentioned by @AnalogSteph above. And all the resistors in the output stage need to be of a similar order or lower. This might be possible, If it is I'm happy to admit it is beyond me.No. The effective noise impedance is the parallel combination of input and output impedances, thus dominated by the latter.
Nice. I'd have preferred a discussion where any errors of fact are corrected, and we can move on with increased understanding. Now you've just tripped my hair trigger ignore button.Why is that clueless people
That's indeed what I did, didn't seem very efficient.I'd have preferred a discussion where any errors of fact are corrected
Fair enough, so you did. And I apologise. The specific statement of mine regarding input resistor noise was factually incorrect, and I steadfastly ignored your hint to that effect.That's indeed what I did, didn't seem very efficient.
Reading this may prove enlightening, in the case of a non inverting configuration R4 is the input impedance.
To be fair, the first post of the thread links to marketing material that is, ihmo, not at the level of the invention. Better reading the audioxpress article, and eventually the patents, to have a better understanding of the system.Why is that clueless people always question the performance of an expert product they have no clue about?
This just boosts the bad reputation that ASR already has even more.
DR and SNR are different metrics.Even your amps, which achieve stellar performance in the world of audio amps, have full power SNR some 60dB short of the dynamic range needing to be achieved by a genuine 28 bit DAC.
But (I think - and I'll bow to your greater knowledge if wrongDR and SNR are different metrics.
It may be an issue of Amir's measurements, but again - if I've understood correctly, in the review I linked for the ARTHUR 2408/N2 it was measured at 115/116.Full power SNR from my amps is around 130-135 dB
The 2408/N2 was discontinued 2 years ago. Amir also measured the Arthur 4222/E1 at 125 dB, it is indeed the "noisiest" amp we sell today. But we are off topic.It may be an issue of Amir's measurements, but again - if I've understood correctly, in the review I linked for the ARTHUR 2408/N2 it was measured at 115/116.
Fair enough (I didn't deliberately choose an old review by the way - when I search for Boxem or Arthur in the review index, the 2408 is the only one that comes up)The 2408/N2 was discontinued 2 years ago. Amir also measured the Arthur 4222/E1 at 125 dB, it is indeed the "noisiest" amp we sell today. But we are off topic.
