thats just it... He's only talking about the positions he tried... the 1/4 wall dimension spacing, that I am claiming is best
Are you? I thought you were claiming corners were best?
When he talks about what he thinks is best, he's talking of the positions he experimented with, 1/4 wall spacing is Not one those experiments.
Both corners and different variations of 1/4 placements were tested as seen on pages 19, 20, and 23.
In which the results show that numbers 6 and 11 were best, with number 6 having the best low frequency output. This is what I've been using in my rooms, for two reasons. First, after moving subs all over the place, front+rear measures the best. Second, it happens that it is the most convenient placement because it's much easier to keep the subs out of walking spaces, unlike subs at the sides. Since my rooms tend to be narrow, you wouldn't be able to squeeze past side subs to sit down. One sub is next to my center speaker, with a wall-mounted OLED screen. The other is behind my seats along the wall.
I also haven't been able to accommodate corner placement in any room so far because up front, they would interfere with the speakers, and in the back, I may not actually have corners to use.
Most consistent response is from 6 and 11 (mid-walls).
As you brought up, he apparently does not test the theoretical double 1/4 distance setup from earlier, or whatever it should be called. Why, I have no idea. So since it is only theoretical, it is hard to say that it is the best.
In the conclusion, the best overall response was the four mid-wall locations, however using only front+rear is nearly as good, but with noticeably better low-frequency output. Here's where the corners come into play: when using all 4 corners, you get a response that is good, but not quite as good as the four mid-walls, but with better low-frequency output. Therefore if I had 2 subs, I would use front+rear. If I had 4, I would go with four corners, if you have the space. Often you end up with a door in the way, or the room is open, etc.
You're free to experiment with the close seat corner aka double 1/4 pounder placement though
. But I don't think the locations are as practical as I'd be tripping over them.
