that version dated 03_2021. should be before the ma1 in mind.Hm, i don't remember the first one. Maybe they did not have the MA1 in mind with the first picture?
yes, i confirm the latest version of ma1 (1.6.4 for iOS) works fine with 120ii.But at least the MA-1 now works with the KH120ii fine (after updated firmware)?
PERFECT, I'll be getting mine in July so this is great news!yes, i confirm the latest version of ma1 (1.6.4 for iOS) works fine with 120ii.
yes, after i upgrade ma1 from 1.6.3 to 1.6.4, it recognized the two 120iis and upgraded the firmware. then everthing went on smoothly with no issue.But at least the MA-1 now works with the KH120ii fine (after updated firmware)?
I believe you will be happy with the 120iis.PERFECT, I'll be getting mine in July so this is great news!
Can't believe I missed this, that double cutaway looks AMAZING and the clean dual knob plus switch is perfect - is this a custom Les Paul? I have a '59 chambered re-issue (under 7lbs) but I'm totally smitten with yours now!
Your English is fine. Better than a good number of native English speakers.i received my 2nd 750 but got problem with ma1 when use below connection:
* analogue preamp, left output to left 750, right output to right 750;
* left 750 spdif to left 120ii & right 750 spdif to right 120ii; also tried
* left 750 xlr to left 120ii & right 750 xlr to right 120ii.
i got error message that "the subwoofers got different level signals". if i just connect one 750, i don't have the problem.
according to the on-screen instruction of ma1, i have to use a pair of y split cables to connect both 750s at same time to their L/R chennels to make sure both 750s receive same signals in the both channels. this is unexpected.
Thank you.Your English is fine. Better than a good number of native English speakers.
Yeah - Gibson Custom, Modern DC Standard. They only did a few of these, my colour is not even on the Gibson Homepage. They did alo a run with bindings and gold hardware, was the same price/guitar.Can't believe I missed this, that double cutaway looks AMAZING and the clean dual knob plus switch is perfect - is this a custom Les Paul? I have a '59 chambered re-issue (under 7lbs) but I'm totally smitten with yours now!
good informationI also found time to do a proper setup with MA1. Works perfectly btw.
And - it took the whole speaker to the next level. They should put a microphone to every speaker pair - it makes no sense to sell them without.
It was the same as I remembered from the setup KH80 + KH750 I did for a friend. Very good balance and a hint of ""truth" in what you hear. Very wide stage and REALLY good phantom center.
I have way more expensive and fancy speakers next to them and yes - KH120ii is missing the lowest octave, therefore the KH750.
But I cought myself thinking "do I really need better to work?". And when you know me - that means a lot
What's the other more expensive speaker?I also found time to do a proper setup with MA1. Works perfectly btw.
noFor someone with KH120's and a 750, are the KH 120 II's a worthy upgrade or a more "incremental" upgrade? This is solely for listening to music type of perspective. Not using for any type of mixing/mastering/etc
The note tells the tale - data approximate below 100 Hz. I have both sets of monitors and I assure you that as good as the KH120 II is, it does not go lower than the KH 150.Is it just me or does the 120 have a better on FR and go lower than than the 150? Both are from the SOS reviews
120ii:
150:
Do you prefer one over the other? Is the 150 worth the premium all things considered? I’m not the most well versed in audio speak so thanksThe note tells the tale - data approximate below 100 Hz. I have both sets of monitors and I assure you that as good as the KH120 II is, it does not go lower than the KH 150.
