- Joined
- Mar 18, 2023
- Messages
- 671
- Likes
- 1,041
I feel the KH310 MK2 are coming soon, the price for KH310 on Thomann is 1823€ vs 1454€ for KH150, that is as low as I paid for them back in 2020
New KH310 would probably cost more than current ones unfortunatelyI feel the KH310 MK2 are coming soon, the price for KH310 on Thomann is 1823€ vs 1454€ for KH150, that is as low as I paid for them back in 2020
For the last two years KH310 MK1 were about 200€ more, my guess is MK2 will be priced at 2500€ or soNew KH310 would probably cost more than current ones unfortunately
They're double the priceHow come?
Always been my view. Our ears are degrading no matter what. Buy now. I'll buy less and less stuff as time passes. Plenty options to get accurate and balanced sound at any price.If I understood your situation correctly (by now), it appears financial constraints are an important factor for your choice. Which is quite normal, I do not even have the money to buy a new pair of 120 II’s.
Which is why your question appears quite illogical to me: for full range reproduction, you will need bass management in both cases. My speakers play to ~43 Hz -3 dB and I will add a subwoofer soon. It’s perfectly fine listening on them to all sorts of music. Bass “oomph” (@SlothRock) is usually around 100 Hz. Sub bass is adding scale, not power to the bass presentation.
Bigger woofers are more important to control distortion. Neumann did manage to have very little distortion with the small woofers, and adding a sub will further mitigate the issue.
My x-mas present to you, to react again to your ever circling, inconclusive questions, I want to finish with an advice that I gave to you before: buy what you can afford, and buy it now. Do not think about the question whether (in the case you won the lottery?) you should invest ten grand Schekel for the best system there is. In ten years, cardiod active speakers might be a mainstay in consumer audio and you might prefer this technology.
Then again, as I see myself painting this image: probably you should just wait ten more years...
Happy holidays, stay safe.
How's the sound ?View attachment 338577Well, well, well! Happy New Year!
How's the sound ?
I'm interested to see you try a surround setup now
I’m sure that’d be incredible but im now maxed out for space on my desk setup. I decided to go for the 150’s because even if a 310 II came out it’s just too wide for me to want to fit on my desk (and too expensive lol) and I don’t have the space behind my desk to put them on speaker stands/behind the desk. So unfortunately surround doesn’t feel possible.I'm interested to see you try a surround setup now
I should find somebody with a KH80 and put it next to one of my 420s to do this
That would be hilariousI should find somebody with a KH80 and put it next to one of my 420s to do this
It will be interesting to see. I have a pair of KH310's as well as several other Neumann monitors in my studio - including KH 150's and KH 120 II's). It will be particularly interesting to see how the new KH 310's compare to the KH 150's.I feel the KH310 MK2 are coming soon, the price for KH310 on Thomann is 1823€ vs 1454€ for KH150, that is as low as I paid for them back in 2020
These two ways don't seem to get past the part where the speakers are made silent to check levels in the MA-1 calibration. (I also tried going the way in the manual says too.Hello Filio45,
Both versions are possible. Going into the monitors first reduces the overall system delay because of the latency free digital out of the monitors.
