Neumann KH 150 Monitor Review
Rate this studio monitor
    Votes: 0 0.0%
    Votes: 3 0.6%
    Votes: 44 8.5%
    Votes: 470 90.9%
dfuller
I see no reason why aluminum would work for KH120 and not KH150
I'm assuming it's just too expensive so they used different materials
Too expensive (both for the tooling and for the shipping weight - idk if you've ever picked up any of the aluminum body Genelecs but they are incredibly heavy for their size) and doesn't make any appreciable difference if I had to guess.
tuga
Oxford, England
Appreciable is relative/subjective.
Genelec 1031A (1999)
https://www.stereophile.com/content...-monitor-1092a-powered-subwoofer-measurements
Genelec G Three
https://www.stereophile.com/content/genelec-g-three-active-loudspeaker-measurements
DevinCortno
Pearljam5000
If it doesn't make a difference and it's more expensive for them
Then why are they still using it for many years?
dfuller
Because they've already paid for the the tooling (which is very expensive) and redesigns take time and money
dfuller
Not for nothing, but the KH150 doesn't show resonances like the 1031 does.
Also the 1031s are substantially nicer sounding than 8050s, so do with that information what you will.
Don't think it's the only reason
They could have made the Ones from any materiel and still chose it again
How the hell did we end up talking about Genelec when we were talking about KH150 vs KH120????
SlothRock
The answer is simple: Make more money using plastic, make less using Aluminum + they can get the measurements to be incredible with either material so why spend more when you can spend less and simply charge more? It's a business after all.
Pearljam5000
Aluminum is more durable and sturdy
Alao looks and feels better
Even if sounds the same
Pearljam5000
Got confused with the different threads :)
jhaider
I already emailed you guys twice and no response yet.
I suspect they have a backlog of emails due to the software as currently staged on their website being broken. I have one in to the headoffice address too.
Moonhead
Denmark
More people should use the ignore button on the constant Vedder Machine,
so he doesnt beg and pollute every Neumann/Genelec thread.
CMB
I once heard the KH150 and the 8351 one after another in the same room. Of course, this was not a controlled test, I just listened to a few pieces of my music at different volumes. But it was the same for me, for me the 8351 would have been out of the question under these conditions and without EQ, because it was too much treble for me.
But of course, firstly, it may be that there are different preferences and someone else might have found the KH150 too dark. Also, I suppose that if I were forced to use the Genelec, I could just EQ the treble down a bit. That should be very easy to do with them.
That's why I think you'll be fine with all these speakers and nothing bad can happen in real-world use. Some people make it sound like it's an incredibly important decision whether to choose Neumann or Genelec. I think it's great that there are at least two excellent manufacturers in this field, who on the one hand both reliably produce good products, so that you can actually buy them all blind (if you respect the use case they are meant for), but at the same time also differ sufficiently so that you have a choice.
One of the advantages of Genelec for me is GLM.
It takes you less than a minute to adjust the trebble in your speakers for instance. And, that includes the time to connect your labtop to GLM to the Cable hiden behind the speaker.
From what I could read here, it is better to have a bit to much and be able to EQ it down, than to try the contrary.
From experience now, after I had tuned the trebble down at the start, with time I tend to prefer to come back more flat. But then, maybe I am just compensating for my old ears.
TimVG
VituixCAD calculates also DI slopes and shows in Preference rating window. See two cells in blue background.
Hi Kimmo
Have you considered adding the option of using the LW as a baseline for calculation of the DI instead of the ON.
Kind regards
