Need new amp!
Nicasdream
I want to upgrade my gear but don't want to over pay for something I don't need
Currently have a pioneer elite A-20
And a pair of polk lsim 707s
In a 11 x10 room with treatment and listening to music around 80db to maybe 85db with peaks into the high 90s
Mostly listen to jazz and rap and then everything else
Just not sure how many watts I actually need
I'm getting a rotel cd11 tribute
And was thinking about getting the rotel a11 tribute to go with it but also considering going with the
Rotel rb-1582 and the rotel 1572 pre
But not sure if it would be overkill for me
Since I listen from 6 feet away in a small room at around 75-85db with peaks in the high 90dbs
Any help or recommendations would be helpful
Zek
Look here
N
Nicasdream
So like around 90watts
For 85db with 17db max peaks
After that everything is a waste right?
Kind of wanted to try separate components but without wasting money and using the equipment to it's potential
N
Nicasdream
Everything is hooked up
Went with the
Rotel rb-1582 mkii
Rotel rcd-1572 mkii
Cd11 tribute
It sounds really good listening at the same db's and it doesn't sound loud and I'm hearing things I haven't before
GD Fan
NY, NY USA
Rotel makes excellent stuff.
Am I reading this correctly that you bought two different CD players?
Chrispy
PNW
New gear can enhance that hearing things you haven't before thing :) I was going to say that A-20 is a fairly minimal amp, could well use some more watts....altho I'd find something better priced than that Rotel power amp. I usually use this spl calculator, hadn't seen the biamp thing before. The pre-amp is an RC1572mk2?
GD Fan
NY, NY USA
Looks like RA1572 is a pre. RCD1572 is a CD player. So, probably a typo.
Damn redundant use of nomenclature by Rotel.
N
Nicasdream
Yeah RC is the preamp still wondering why you would want the cd player and preamp
And I'm not going crazy I think maybe the A-20 was straining a lot because I'm listening at the same db's and it doesn't sound boomy and like there's too much sound in the room
I honestly thought I wasn't going to hear a difference I'm scared now XD for my next system $$$
And I'm sure there's better gear for the money I spent but it's simple ordering online
Chrispy
PNW
Your post of listed equipment seemed to cite the cd player instead of preamp....
How do you know you're listening at same levels? Got some measurements to share? Boomy could be for a variety of reasons.
N
Nicasdream
Yeah it was auto correct
But I got the
CD tribute as a transport
RC pre
Rb power
And just have a galaxy audio db meter as my reference for the db's
I just hear everything more tight and refined and every song feels like the bpm is slower I guess because I'm hearing less distortion
I have my fender twin reverb tube amp on top of my audio rack don't know how it's altering the sound and I also have some adam audio 8" studio monitors behind my main speakers that I use for backing tracks
Have to tweak that I think
Chrispy
PNW
But I got the
RC pre
Rb power
Auto correct is so often correct wrong, I just disable that kind of bullsh*t. But I can spell, so maybe that's unusual.
Like to hear more about that extra amp/monitor you're using and why (audio reproduction isn't the same as audio production).
Tight and refined means what in real world stuff?
N
Nicasdream
Well the Adam audio monitors I just use when I'm playing my guitar for backing tracks
And by tighter and refined I mean it's more focused
I'm also a novice astronomer have you ever looked at something that is out of focus be it a telescope or camera ect
It sounds like that like I just turned a knob a little closer in focus by buying this gear
I'm listening to, miles, Johnny Cash, Elvis, 2pac,grant green, mobb deep, chet baker and wes Montgomery ect
And everything sounds more clear and precise
