Motu M4 Audio Interface Review
Blumlein 88
Check out the 8pre-es. It's a fantastic interface. I've been using it for 6 months and it's a phenomenal value. If I recall correctly, the specs are also better than the Scarlett. We actually bought the Motu to replace an earlier Scarlett 18i20. The motu blows it away although the Scarlett was a gen 2 and their gen 3 stuff is much better, so I know it's not a fair comparison since I wasn't able to test the latest Scarlett against the Motu, but I can say I'm really happy with the Motu.
The key words were comparably priced. I would expect the 8pre-ES to better the 18i20, but it cost a goodly portion more. The 8 pre Clarett would be more comparable in performance and price.
thefsb
Worth mentioning is that the volume knobs on the Motu M2/M4 feel amazing and super-precise. I was relieved to confirm that it has a good DAC so I don't need to get something else and lose those that fine volume knob.
The HW feels like really good quality. But the controls behave a but odd. I often notice a significant lag between adjusting the monitor mix knob and it taking effect. Seems as though the control is coarsely quantized too but don't think it is, the lag turns the adjustment into a step. It's disturbing if I forgot to expect it. Not a big deal, just not typical of audio controls.
thefsb
You know the Scarlett gear, at least the better ones, seem to be craftily made on the edge of inaudibility. Meaning some of them are good enough you'll likely hear no difference vs better gear or it will be a tiny very slight one heard only rarely. To me that is pretty good for low cost entry level gear. They did make a couple particular versions not quite that good. But mostly Scarletts are that good.
The M2 and M4 appear to be even better and nothing wrong with a little gilding the lily. MOTU doesn't yet have anything comparably priced to the Scarlett 18i20 with 8 microphone preamps. But maybe in the near future they'll have an M8 or something like that.
I blew up my Scarlett Solo (together with computer mobo) by mistake and got M4 as replacement.
I was not happy with the mic preamp on that Scarlett solo. I use two mics, AKG D880 dynamic handheld and a Sure SM35 headset condenser that has a preamp incorporated in its XLR connector. Both require max gain (or nearly). Noise with those mics using the Scarlett was so bad that I bought a copy of Metric Halo Channel Strip to clean up the recordings (voice on educational videos). No problem with the M4.
Blumlein 88
I don't doubt that. But not all Scarlett's were the same. The 18i20 had good preamps with 60 db of gain and good EIN for no significant noise problems.
AnalogSteph
.de
Maybe that was an older (1st gen) model then or it had some sort of other issue. EIN specs improved from -125 dBu to -128 dBu from 1st to 2nd gen (and that's about what Julian Krause measured in the latter, too - and fun fact, the M2's was a fraction of a dB higher if anything), but that shouldn't be night and day.
Good upgrade either way. These MOTUs are getting seriously close in performance to the next tier up, and you've got more inputs and outputs to boot. And should they ever run out of ESS 9016s, some 9026s would basically drop right in if memory serves.
PuX
You can look at Archimago's site. That used to be what he used.
http://archimago.blogspot.com/2016/07/measurements-focusrite-forte-usb-audio.html
Here he compares the Emu 0404 to a Focusrite Forte which replaced the EMU until he purchased the RME. Measurements of both devices.
Here he compares measurements of the Forte, EMU, and RME.
http://archimago.blogspot.com/2018/09/measurements-rme-adi-2-pro-fs-adc.html
nice, thanks.
I believe NwAvGuy also had one and posted something about it. Here, for example http://nwavguy.blogspot.com/2011/02/rightmark-audio-analyzer-rmaa.html
LT1
El Nino said:
“No... there's only one set of filter coefficients... at 48kHz, the stopband will begin at 0.54fs, i.e., 26.2kHz. Just as "lazy" in the sense of the word you're describing. Except it isn't lazy... it's an intentional design choice. At 44.1 and 48kHz fs, there is no possible digital filter that simultaneously provides flat frequency response to 20kHz, linear phase, fs/2 stopband, and good time domain performance. Filter designers have to weigh the options and pick a middle ground. This is why the very expensive AK4499 also doesn't include a sinc filter with fs/2 stopband, even though it would be exceptionally easy for the AKM engineers to include.
There's a lot of misinformation about digital filters on this forum unfortunately.”
Agreed. Fortunately, there is a trove of correct information about digital filters available. My personal favorite is Multi-Rate Signal Processing for Communications, fredrick j. harris (SIC), Wiley. I’m sure that there must be articles, more accessible than a textbook, that can be found on the internet to cover this same information. I apologize for the fact that the following is not easily accessible to one not skilled in the art; I offer it in the hope that perhaps someone who is might generously take some time to make this accessible to more members.
There is clearly a significant number of people on this forum who have mastered DSP of sampled data. I hope some of these will take the time to explain that the ideal filter is a brick wall with the wall located at exactly Fs/2 which produces a sinc function in the time domain (TD) with nulls at every other sampling point. If the brick wall is at any other frequency than Fs/2, the other samples will not lie at nulls and we would have inter-symbol-interference (ISI) which will manifest as distortion. Any TD waveform that has zeros at all multiples of Fs other than zero could also be used but the sinc is easiest to describe and would be most familiar. Of course, a brick-wall filter is non-realizable.
In practice, one can take a relatively narrower frequency domain (FD) pulse of width alpha/ Fs/2 and convolve it with the desired theoretical brick wall FD filter response and produce an ideal trapezoidal pulse in the FD. Since convolution in one domain is identical to multiplication in the other domain, the zeros of the sinc function will still be present, and no ISI would be introduced. In the Linear TD, the fact that we can only approximate the sharp transitions of a trapezoid results in slight rounding to a sigmoid shape in the FD. Other shapes are possible that depend on the FD waveform convolved with the Brick-wall filter waveform. I am sorry that I cannot take the time to show plots. I am attempting to describe a classical Nyquist filter for Fs/2. It would have its response at Fs/2 exactly 6-dB down from the peak. The pass-band ripple requirements (low to prevent TD echoes), transition width and stop band attenuation (say 80 dB) desired will then determine the number of taps necessary to implement a Nyquist FIR filter with symmetrical coefficients resulting in linear phase vs. frequency leading to the constant group-delay (GD) necessary for 0 distortion (at least over the signal bandwidth). I focus on over-sampling DACs because the analog output filter, which in an NOS DAC would be entirely responsible for the waveform reconstruction, which involves filtering out the replicants. No analog filter can have perfectly linear phase, but with a higher sampling rate, the replicants are so much farther away (176.4 for 4x oversampling) that the filter transition zone can be much larger which allows it to be simpler and to have much more linear phase over the signal bandwidth.
The large number of taps in the digital FIR may result in an amount of GD that may render a particular filter unsuitable for applications where audio must be precisely time-aligned with video. Perhaps short FIRs, albeit with compromised performance, may be perfectly adequate for such applications.
All the DAC chip manufactures are well-aware of this and as far as I knew until El Nino’s statement above, all over-sampling DAC chips provide at least one filter that at least approximates the classical. Then regardless of the FD shape of the signal they convolve with the FD brick-wall filter, the ISI will be zero, but the filter may be down somewhat more than 6 dB at Fs/2. Variations in the shape of the narrower filter can result in the amplitude being 6 to 12 dB down at Fs/2 and the
In the conversion from say 24/96 recording to redbook CD, the desired data is strictly band-limited 20 KHz. Here, a band-limited signal It is sufficiently attenuated above that frequency so as not to produce any significant images. Since the sampled data inherently has replicants at all integer multiples of Fs, then replicants exist at +/- 44.1 KHz. The band-limited signal is negligible below 24.1 KHz. The filter transition zone is from 20 to 24.1 KHz and therefore all the DAC chip manufacturers at least attempt to have the filter reach full attenuation by 24.1 KHz. I’m sorry that I cannot take time to develop tradeoffs of other filter parameters mentioned vs. the distortion introduced and especially the audibility thereof.
I believe that the DAC chip manufacturers are neither lazy nor misinformed; quite the contrary, in that they provide what the above discussion finds as the proper filter design for sampled data. Incidentally, the exact same filter taps designed for 44.1 KHz data would serve perfectly well for 48 KHz data as long as it is clocked at the correct sample rate.
If I had to reduce all the above to a single conclusion, assuming that redbook CDs or their rips are of interest, I might state:
“If you want an oversampling DAC, look for a filter response that has strong rejection at 24.1 KHz and above and is down by 6-12 dB at 22.05 KHz with a top that appears flat to 20 KHz and always look critically for distortion.”
While there is so much more detail that I don’t have time to provide, e.g., compensation for the DAC’s zero-order hold (ZOH) effects on the associated analog output filter, etc., I hope there is a sufficient skeleton here for others to augment what is provided above. I apologize for not making this more accessible and apologize in advance for not being in position to respond to questions. This is my first, and probably last post. Please feel free to flesh it out so that those members so inclined may have better access to the correct information, at least at a high level, that they need to make informed decisions.
LT1
Alex___
@amirm thank you for your review of the motu m4! But it seemed strange to me, why you are testing ADC Motu (m4, 624) in unbalanced mode? Other audio interfaces have been tested by you in balanced mode (Focusrite, RME ADI-2 Pro, Lynx Hilo, RME Babyface Pro FS and etc.). After all, this affects the final result of noise and thd + noise and the rating ADC may not be entirely correct.
Tks
Same reason he didn't test 4V >_< probably drunk :cool:
zandm7
@amirm Nice review, thanks again for all you do.
Any chance you could show SE performance on the DAC portion of this device? Interested to see if it differs at all from balanced...
audio_tony
Leeds, UK
I guess you can specify the sample rate and bit depth on Linux when you open the device with Jack, which serves the purpose of ASIO.
When using command line tools like sox, aplay, arecord and so on - you can set the sample rate and bit depth on the fly.
You don't even need jack or pulse audio for that.
dfuller
So, this is bus powered 5V ..... and it can deliver more than 5V at the line outs? How does it work??????
DC-DC converters. More than likely boost converters rather than charge pumps or similar.
