Thanks for the response.
But I can clearly hear the difference for an Antelope Audio Discrete 4 SC. Other league in terms of clocking, etc?
My monitors are ADAM A7X.
Three most likely reason for you hearing that difference.
1 - Level matching not sufficently close between the two devies when you compare.
1a - or you have a non optimal filter applied on one of the devices.
2 - Antelope Audio has audible levels of distortion, and/or noise. (Or it has some sort of effect DSP applied, and altering the sound that way)
3 - Cognitive biases, causing you to percieve differences when in reality there are none - assuming you are not comparing blind. Everyone is subject to these, and the differences can seem like night and day, right up until the point where you check blind.
The likelyhood that there are genuine audible differences if the Antelope measures as well or better than the Motu is exceedingly small.
