Bergante
It’s Audio/MIDI. Use the Window menu to open the audio device configuration.Thanks! The MIDI thing thrown me off, as this is completely unrelated to MIDI…
Did this whole thing ever get resolved? I am looking at this interface but bad line level performance with 1/4" going into the front would be a dealbreaker for my use case.If you read the manual, I don't think it says anywhere that inputs 1-2 are supposed to be used as line inputs only if using XLR connectors. In fact, it says the exact opposite on page 17:
I'd say it's actually more likely that people will want to use phone plugs to connect line level devices than XLR, and the XLR inputs are more likely to be only used for microphones. So phone plug inputs on the combo connectors really should work just as well or better than XLR for line level sources.
I'll try some tests on my own unit when I get back home so next weekend at the soonest.
Occasionally I'd love having line inputs with gain that doesn't need to be applied in software and besides the device was always marketed as having 4 instead of 2 line inputs anyway. If there really is some kind of a design error here, I wonder what to do? There's still plenty of the warranty period left in case I'd try to get it exchanged, but are there even any revisions which don't have a problem? I do like the unit otherwise.
I have Motu M2 since it came out and Win10x64. There are no problems with drivers.I have a slight buyers remorse (audient ID4 MK2) still in return period and im now looking at motu M4. My use would be as a mic input + amp dac for various headphones/iems. The issue is i read that the high output impedance from the ID4 MK2 can negatively affect the FR on low impedance devices and i would like to avoid that.
Would it be worth returning the ID4 and get the motu M4 if i use low impedance IEM's a lot? I need direct monitoring when using voice chats on IEM's otherwise i fumble my words if i cant hear myself speak. I did also read that motu M4 possibly has some driver issues on windows which also worries me lol.
Highly appreciated if someone could give pointers.
My m4 came in the mail yesterday and I got a chance to test it out.Is it correct that inputs 3-4 can only be monitored hard panned as stereo? What if I want to plug an external channel strip into input 3 and direct monitor a bass guitar while recording? I will only hear it out of the left speaker/headphone? Is there any way to center it using the Motu software or is it just hard wired that way?
If this is true it is disappointing, as I wanted to use the line inputs on the back to plug in external preamps for mono things like bass and vocals, not necessarily for stereo keyboards as it seems it was designed for.
Thanks
That's what you get with a no-frills digital volume control of a certain step size, you basically hear the volume jumping. Should be particularly noticeable on bass.I probably could have lived with that, if not for a much bigger problem: weird digital crackling when adjusting the monitor mix knob or preamp gain knobs while playing an instrument plugged into any of the inputs and direct monitoring.
I have never heard anything like it on other even cheaper interfaces… focusrite, presonus, apollo, none make weird digital cellophane ripping noises while adjusting levels.That's what you get with a no-frills digital volume control of a certain step size, you basically hear the volume jumping. Should be particularly noticeable on bass.
Certainly you wouldn't be adjusting the levels all the time though?
Is it an actual pot controlling the volume, or a digital rotary dial? If the former is it possible it is just pot noise?I have never heard anything like it on other even cheaper interfaces… focusrite, presonus, apollo, none make weird digital cellophane ripping noises while adjusting levels.
Sounds about right. Bass is approximately DC in this case. You basically get to hear what a step function sounds like every time the volume makes a jump.It only happened while playing bass and adjusting levels while direct monitoring.
