So, some recap about THX 887. I ordered 2 of them, the first one a week ago and it died 2 days after just when I was listening a music. It just turned off and that it. I contacted the support (monoprice.eu, btw) and they sent me the second unit on another day and requested to send fault unit back charge free. So, about the amp and some comparasions with my current Monolith Liquid Spark:
1. Clarity: I didn't heard any differences between 887 and LS. they are sounds equally clean and transparent
2. SQ: 887 more dry/clinical sound/sterile, LS a little bit warmer, just what I like. Maybe it's just a placebo. may be.
3. Loudness: from SE LS spark much more powerful, I mean noticable powerfull. LS on default gain 12 o'clock position produces the same amount of as 887 on 3rd gain 12 o'clock. Through balanced output 887 produce the same amount of loudnes on the 2nd gain 1 o'clock. As I understood, for the best performance you need a balanced DAC with 4V output, but in that case the 3rd gain may produce clipping(???). I understand that the sound will be so loud, that you will not need 3rd gain, but it just shows us, that smth wrong with the amp's internal architecture if it can't fully handle balanced input. that's a main reason why I decided to return 887 (even considering, that I bough it for 204 euros, 50% off).
4. When it turned off there is some static/electricity when you touch the body of the amp (bad grounding?). this is the second reason which just proofs my concerns about build quality. the product with 407 euros price tag shouldn't have this type of faults, especially if an amp with 110 euros price tag (LS) don't have such things
5. Volume knob on LS is way, waaaay better than on 887.
After all I think I will stick with my trusty LS a little bit more and maybe will buy another dac instead of Fiio K3, or will not buy. I don't think I will hear any differences with another setup and it just looks like snake oil(rabbit hole, etc.) for me
