Monoprice Blackbird Review (HDMI Audio Extractor)
Rate this HDMI Audio Extractor
    Votes: 16 12.4%
    Votes: 47 36.4%
  • 3. Fine (happy panther
    Votes: 53 41.1%
    Votes: 13 10.1%
respice finem
Likely stupid HDMI, I find so bothering how this standard struggle so much with backward or universal compatibility. You didn't pay much but it's not the case for all including AVRs that has such a low lifetime. How is it that a wired connection cannot achieve what a wireless connection like WIFI can do in term of robustness and widespread compatibility. It amaze me.
The "real stupid" is mostly not HDMI in itself, but the dreaded "HDCP handshake".
Ceterum censeo: DRM is a curse.
delta76
While this is correct, it is not the question I was answering, see here:
Converting eARC multichannel to Toslink 2-channel is no advantage (for me) compared to using the TVs toslink out, without an external device.
The only "indication" would be indeed a very "lousy" TV toslink output, which I didn't come across yet (doesn't mean it can't happen).
True. But as I mentioned above the scenario this device makes the most sense is a middleman between an audio streamer and a stereo sound system. I would argue that a hdmi to toslink converter would be simpler. For hometheatre, hdmi 2.0b or better is a must, unless you have an old 1080p TV with no HDR.
beagleman
Pittsburgh Pa
The "HANDSHAKE" prevents the video from showing on my one set up..OFTEN!! I just get a blank screen till I unplug and restart everything.
It will do this maybe once a week....frustrating.
abdo123
Brussels, Belgium
Some people have a playstation 5 but no TV. They have a monitor with no audio processing capabilities. This can give them an outlet to get Audio out.
Lambda
Some/Many modern TVs don't have toslink out. (don't ask me why)
Also Maybe this is good way to connect a DAC to the PC instead of using USB or USB to SPDIF Toslink.
@amirm How would this work with synchronous / asynchronous transmission
You said with an (modern) USB DAC the DAC is the master clock.
But with Video, audio needs to stay in sync.
My Monitor/TV has a fixed frame rate and so dose my video.
What's the master clock in a setup using this Extractor?
PC/GPU or the TV/Monitor or this thing?
abdo123
Brussels, Belgium
With SPDIF the transmission is always synchronous so the device will be the master clock.
SMc
I wish this had been available when my Integra HDMI products died. I tried a different Monoprice extractor that didn't have a Link setting so I was limited to stereo which was superfluous to the tv's optical output.
Would one of these plus the Aiyima A9 be a cheapskate AVR if the tv sends multichannel? Would "bitstream" do Dolby?
delta76
If you have a ps5 and use this to extract audio, you are doing it wrong, very wrong :)
DonR
Vancouver(ish)
Would have been a great tool for me if it support ARC.
delta76
What would you use?
As mentioned in previous post, this is not even HDMI 2.0. you lost a lot of features from ps5 for nothing. At this point HDMI 2.1 audio extractor is not available yet. Best bet is earc audio extractor
JanesJr1
MA
This is a review and detailed measurements of the Monoprice Blackbird 4K series HDMI 7.1 audio extractor. It was kindly drop shipped to me by a member and costs US $30.79.
I like the Link light which indicates signal on HDMI input. The switch lets you "lie" to the source and tell it you have 8 channel audio even though your TV for example only has stereo. For non-PCM data you have the "bitstream" to pass it down to another decoder. Back panel shows a very useful Toslink optical output in addition to 8 channels of audio:
Yes, you have to use 3.5mm plugs but hey, you didn't pay much for this! :)
In my use, the box nicely attached to the output of my PC Intel HDMI output. One other fancy/expensive one I tested would not work at all. Alas, I could not get the output to work with my computer monitor. Maybe it is pilot error. Maybe it is the stupid HDMI. As with all of these products, compatibility is hit and miss so be ready to return it if it doesn't work in your setup.
Monoprice Blackbird Measurements
Here is our dashboard of HDMI in and analog stereo out:
As noted, it didn't matter which of the 4 channel pairs I tested. They all had the same low output of just 1 volt and SINAD of 86 dB. Latter is caused by too much distortion.
Normally I would be depressed at this point, wondering why I was put on earth. Then I tested S/PDIF Toslink output:
Ah, there is salvation! :) We get basically 24 bit, unmolested output. This means you can connect your favorite DAC and get as much extra performance as you like.
Continuing with analog output performance, noise is actually reasonable:
Multitone is not:
Nor is jitter although audibly is probably OK:
IMD test shows that we are not that far ahead of a cheap phone dongle:
I couldn't run the rest of my tests due to issue of ASIO emulation in my test setup (not a fault of the unit).
The analog performance of this HDMI audio extractor could embarrass a self respecting audiophile. But is good enough for everyday work. The great thing is that you have S/PDIF output for perfect audio to connect to your favorite DAC. There, you could get stated of the art performance. Heck, you could buy this little box as an accessory to add HDMI input to any DAC you want!!! It is so cheap and not much more than the cost of an HDMI cable or two.
Hopefully compatibility is not a major issue. You may want to read about that elsewhere.
Overall, I am going to recommend the Monoprice HDMI 7.1 audio extractor. It is a bargain with great expansion capability.
From the I'm-Not-Afraid-To-Ask-Dumb-Questions camp, what is an "HDMI audio extractor"?
Some of these reviews of audio accessories are interesting, but I often don't know what they are supposed to do ... and still am not sure after reading the review...
abdo123
Brussels, Belgium
the PS5 doesn’t support e-Arc. Or regular Arc.
abdo123
Brussels, Belgium
In the I'm-Not-Afraid-To-Ask-Dub-Questions camp, what is an "HDMI audio extractor"?
Well HDMI holds both video and audio in digital format, this device separates them.
JanesJr1
MA
Why would one want to? I've never used HDMI for anything, but if I do, what does this get me?
GWolfman
ROFL
Now we know what keeps @amirm up at night. :p
So toslink only works for a stereo signal right? What if 5.1/7.1 is sent, which channels would a DAC play (L+R, if at all)? How could one extract the other channels (e.g., center)?
delta76
Who said earc on PS5? It is earc on the tv. I am not aware if any monitor supports earc to be honest. PS5 owners without a tv probably should just use a headphones
delta76
Your old AVR or your sound system might not have HDMI input which is where this device could help. If you read this thread it was mentioned you can use this to feed your streamer like Chromecast to your stereo sound system
