It seems a DEQX preamp might be easier for me than the miniDSP. Also the Anthem SRT preamp seems good. As long as they don’t add flavour to the sound.None whatsoever
Compared to? Amir only measured the DAC in the SHD with digital input and with a SINAD of 112db it is certainly respectable. In my case I use the SHD for all my line level analog sources so the performance of the ADC is just as important as the DAC. I don’t even use the digital input on the SHD and prefer the performance my Gustard x26pro over the internal DAC of the SHD for converting digital to analog. I use the analog output of the Gustard to input to the analog input of the SHD like all my other sources. Yes I know this results in redundant digital processing. The SHD uses one of the best performing ADC chips on the market so I assume it is SOTA. Of course the DSP performance by itself is not transparent but it‘s function is to correct the output from the speakers in the room so that the end result is more transparent to the source. Dirac Live is the application that does this very well.@Ricwa @Stoutblock no noise added in the chain?
Have you compared doing this to sending the digital output to your Gustard DAC instead? This would seem more logical, unless you need the 4 output channels rather than two.Compared to? Amir only measured the DAC in the SHD with digital input and with a SINAD of 112db it is certainly respectable. In my case I use the SHD for all my line level analog sources so the performance of the ADC is just as important as the DAC. I don’t even use the digital input on the SHD and prefer the performance my Gustard x26pro over the internal DAC of the SHD for converting digital to analog. I use the analog output of the Gustard to input to the analog input of the SHD like all my other sources.
These are the two options current vs your proposed alternate. Besides not being able to use outputs for channel 3 & 4 from the SHD, I also have a large quantity of DSD files on my server that cannot be recognized by the SHD digital input. If I connect the server directly to the DAC (which is capable of processing DSD files) I lose the DSP ability in the SHD.Have you compared doing this to sending the digital output to your Gustard DAC instead? This would seem more logical, unless you need the 4 output channels rather than two.
(In my own system I use an SMSL VMV D1se DAC connected to the digital outputs of my SHD for the main speaker signals, with the SHD's DAC now just used for the subwoofer signal.)
Actually I did try the alternate setup several times over the last few years. Even though I have to believe the internal DAC in the SHD is a bottleneck in comparison to the Gustard, I also can’t say I could actually hear a difference between the two setups. I know there is a response difference though because Dirac Live had to develop slightly different filter solutions in the DSP with the Gustard DAC after the SHD in the signal chain. Perhaps without DSP there would be a more significant difference?You didn't actually answer my question but I'll take that as a no . The DSD context obviously gives you a reason to do things as you do. If you do only need 2 output channels (you haven't said) then I'd encourage you to at least give the alternative a try just in case you felt there was an improvement (affecting all playback) that was worth the trade-off of no longer being able to play DSD files. It would cost you nothing other than time to experiment.
Hi @Ultrasonic. Sorry, just sent that blank message by mistake.@Orca5 did you possibly mean to ask a question?
The Flex processes Dirac Live at 48 kHz-32 bits vs. 96 kHz-32 bits in the SHD - Here is our comparison guide , look at this and the feature set may drive your decision.Looking to get an upgrade from my old minidsp 4x10. I already have a streamer (Allo digione). Is there any reason to get the SHD over the flex?
Mainly looking to get Dirac and better dac performance.
I read that the SHD uses a higher sample rate in Dirac, but I also found contrary information about that. Not quite sure if that is even valuable either.
Curious what the consensus is nowadays between these two devices.
Thanks for your reply, that is a very convenient table!The Flex processes Dirac Live at 48 kHz-32 bits vs. 96 kHz-32 bits in the SHD - Here is our comparison guide , look at this and the feature set may drive your decision.
No umik version makes no difference for the Dirac live processingThanks for your reply, that is a very convenient table!
Do I need a umik-2 to make use of the higher sampling rate in Dirac Live? I already own an Umik-1.
Yes, yes I can.Can’t you do it the same way as your PS5 and Nintendo Switch?
I’ve never noticed any sound physically coming from my SHD. On all of my components that have thin sheet metal construction I always add Dynamat to the inside surfaces as they tend to resonate when I have the volume up a bit on my system. I have done this to my SHD so maybe that dampens any sound it may be created on its own? I have had noisy transformers on components in the past and I know it can be an irritating sound.A couple of questions for fellow SHD owners:
Here is a link to the sound: at about 2 seconds into the recording, I press the power button on the remote to put the SHD into standby mode. I've amplified the recording 24dB (and edited out the click of me pressing the remote button) to make the whine easily audible. In real life it's much lower in volume, but just loud enough that when the AC is not running I can hear it across the room if my ears are anywhere near horizontally level with the SHD's position in my cabinet (e.g. if I'm seated).
- I've gotten in the habit of leaving my SHD on 24/7 (I explain why in the next point). But I have noticed that the top of the case is always warm. Not hot, but definitely warm - and it doesn't seem to vary based on whether the unit is sleeping/in standby vs in active use. The warmth clearly is emanating from the front-right corner of the unit, where the PSU is. Is this warmth normal in others' experience?
- Normally I would just turn it off using the remote's power button when I'm not using it. But when I do that, the unit emits a noise - I'm 99% it's coil whine, and it comes from the exact same spot - clearly emanating from the PSU. There is no coil whine at all once the unit has been powered back on/woken up - it goes mechanically silent as soon as I press the power button on the remote to wake it back up. The coil whine only occurs when the rear power switch is On and the the unit has been put in standby mode with the remote. Has anyone else experienced this?
MiniDSP-SHD-coil-whine-320k.mp3
drive.google.com
The unit seems to function perfectly well, but I thought I'd check in about the heat issue because if it's not normal then it could shorten the unit's life and at any rate I'd want to investigate a return/swap with MiniDSP.
I am aware that the simplest way to deal with both the heat and the coil whine is to turn the unit completely off - but do to that I have to reach around the back and flip the mechanical on/off switch every time I start or stop listening, and I'd rather not do that - it's inconvenient and IMHO I should not have to do that.
Thanks for any experiences and insights folks can share!
Mine is left on 24/7 and very slightly warm to the touch. Never any noise though.
