Midrange dome drivers banned ?
I have the German version as Braun L710 in my vintage collection as well as the smaller Braun SM 1002 which both with some EQ still sound good today and have the timeless Bauhaus design from Dieter Rams which was later copied also from Apple:
View attachment 76429 View attachment 76430 View attachment 76431
Great examples!
BTW: When they were current, I also had various Braun speakers, the most interesting were perhaps the electrostats LE1. But I own almost nothing of them today, am not a collector. (Except art)
I always liked the design of Prof. Dieter Rams. He is close to the design of the Hochschule für Gestaltung in Ulm. Bauhaus was earlier. I know both Prof. Rams and Otl Aicher personally, they are among my design heroes. I was able to tell them that myself when I met them. The first time I saw a Braun system mounted on a wall in a chic Heidelberg furniture store in the sixties, I was immediately and forever hooked. I was blown away.
The photo I made in the Braun museum. It is an example of the design of Hans Gugelot. https://www.hansgugelot.com/
It looks like you get to listen to midrange dome break-up resonance with that speaker?
There is a suspicious lump at 4kHz in the midrange driver response. Only about 10dB down, too.
12 pages later and no one has admitted the truth: yes, dome midranges are illegal now. Nobody uses them.
Not correct.
Revival Audio Atalante 5 https://revivalaudio.fr/atalante-5/
Wharfedale Evo series
Yamaha NS-5000
Bliesma made some dome mids from aluminium, paper, beryllium, and fabric. High value items that need to be kept off the streets
Not correct.
Yamaha NS-5000
I knew I should have put that sarcasm emoji there.
Reactions: EJ3
I mean -- my midrange (ahem, treble) driver has a dome in it (albeit an inverted dome). :cool:
These are still legal, but I do believe one has to be at least 21 years old to be in lawful possession of one (much less two). ;)
Good point. We're both members of the exclusive Dome Midrange club!
If I were strongly inclined to use a dome midrange in a 3-way speaker, I would consider this dome by Peerless/Tymphany available through PE:
https://www.parts-express.com/Peerless-GBS-85N25PR03-04-3-1-2-Paper-Cone-Midrange-4-Ohm-264-1494
The diameter is better than it is with the more common 2" domes, but not by as much as you might think if you focus on the "3 1/2" description. The specifications from the manufacturer indicate that the "effective" dome diameter is 6.7 mm = 2.64", and this most likely includes some of the surround. However the slight improvement in diameter gives it a significant improvement in piston area, 35 cm^2 vs. 28 cm^2 for the more common 2.125" dome midrange. The linear excursion is given as 2.1 mm, twice greater than the typical 1 mm value for a 2" dome. The net effect of the advantage in piston diameter and linear excursion is that the advantage in volume displacement is 2.1 x 35/28 = 2.6. With volume displacement 2 1/2 times greater than it is with a typical 2" midrange, this dome midrange should be usable a octave lower, to perhaps 500 Hz, depending on how loud you want it to play. This is low enough in frequency that it would not be unreasonable to build a 3-way speaker using this dome midrange.
The reason for the greater linear displacement probably is more about the motor than the suspension. The coil height is not stated in the specs, but the gap height is given as 3 mm. Together with the low DCV, this suggests that the motor is probably underhung, i.e., that the coil height is probably about 1 mm, about the same as it typically is with a tweeter. Interestingly, the coil diameter is given as 25.7 mm, just barely more than 1", which obviously means that the coil former joins to the dome not at the edge of the dome but rather slightly inward from the edge of the dome. If the manufacturer's graph of frequency response is to be believed, it is extremely flat from about 150 Hz to 2 kHz. It would be interesting to see measurements of distortion for this driver, because it may well be the ideal midrange to fill the directivity gap between a 6" or 7" woofer and a typical 1" tweeter. For a woofer larger than this, I would still go with a larger midrange.
There is also a true 3" soft dome by ScanSpeak, however it seems to offer minimal advantage over the smaller domes because the linear excursion is .8 mm. It uses an overhung motor with coil height 2.9 mm and gap height 2 mm. This is a little surprising given that the coil is 3" in diameter. This suggest a somewhat high value for DCR of the coil and somewhat low efficiency and sensitivity. DCR is 5.7 ohm and sensitivity is quoted as 92 dB. However this quoted sensitivity value is very misleading because the response has a horrific peak. To be usable down to 500 Hz the peak will have to be squashed and the effective sensitivity will only be about 85 dB, not so good. The peakiness of the response will be further exacerbated by the high Q of the driver unless the enclosure for it is impossibly large, because total Q is 1.73. The same issue is encountered to a lesser extent with the Peerless dome, which is similarly open in the back, but which has Qts .63. While this is greater than is to be desired it is usable, even though it wants to be given as much volume as can be allocated to it. (Qts is greater than the maximum value at which the enclosure volume would be less than Vas for resulting system Q of .7; Vas is 1.6 liter. This suggests that in a typical application its response will likely exhibit a modest peak at the low end, however it should not be difficult to correct this in the applied high-pass filter.)
Once again the fundamental limitation of large domes becomes apparent. The large diameter of the coil implies greater mass and larger DCR, which confounds good efficiency and sensitivity. It is manifest that the motor should be underhung to avoid this fundamental drawback, but even when the coil is short, sensitivity is barely acceptable without using larger diameter for the coil wire, and larger diameter for the coil wire increases the mass, such that it ends up sort of like a dog chasing its tail so to speak. Ultimately in order to achieve a flat response to adequately high frequency it is necessary to use a coil that is both short and small in diameter, like Tymphany did with the GBS-85N25PR03-04. If I were wanting to build a 3-way speaker with a woofer not larger than 6.5", I would seriously consider using this dome midrange.
I'm gunna get a pair to play with they're too cheap to miss out on thanks for reminding me about this driver
They must be good if Genelec uses 4 of them in that new active speaker xD
Definitely not what Genelec is using for the 8381, FWIW.
I take a great deal of personal responsibility for my health. It is my opinion that for many things safety regulations (which I am NOT opposed to) still have become often too restrictive and aimed at the absolutely lowest common denominator. The elimination of lead from solder is probably my favorite example.
Thus I am willing to use solvents, solvent based coatings, acids that are becoming harder to get and other things that the state of california has determined may cause cancer.
But I don't play with beryllium. I would never use a beryllium driver that did not have the cage on it. The pure metal probably does not present too much of a hazard but because of its stiffness I think it can shatter yielding sharp edges. In another life I do some gem cutting and beryls are one of the things a person can cut but I think I will generally leave those alone, even though synthetic emerald and other beryls(beryllium oxide) are available. Beryllium is on the list of things I don't play with. (along with hydrofluoric acid, organomercurials, toxic gases such as mercury, fluorine , arsine , phosphine etc. and certain radiochemicals)
As much as I love beryllium drivers if I were a manufacturer I wouldn't even consider doing anything like it. Berylliosis is an ugly condition with not much liklehood of cure. Ocassionally one sees be drivers with the cages removed. No thank you. But as long as the diaphragm and cage are intact I don't mind having them. One could almost make a moral case against their existence. But they do exist and I like the way they sound. They measure quite well too. (See Toole page 453)
No I have not heard the new Zylon drivers. I am not very interested in them because there is zero chance I would ever buy them. ( I would need three or even five of them) If they have a suite next time (if ever) I go to a show I will take a look listen. I avoid audio stores. I consider them to be disreputable places.
We have only your opinion on that. Whereas the NS1000 drivers and speaker systems have been characterized in two highly regarded textbooks on loudspeakers one in the 1970s and one very recently.
When I built my big speakers in the mid 70s I bought the Yamaha Be drivers unheard. I was quite lucky to have guessed right. Even wholesale they were quite expensive. About $4,000 1977 US dollars.
I have some styluses that have beryllium cantilevers. I am always making sure not to lick them when I am using them.
I am with you on the overbearing of the safety regs. going several steps too far.
Things that the state of California has determined may cause cancer. May only cause cancer in the state of California. As most people elsewhere will use normal, sensible, safety precautions when they use dangerous things. Apparently: the State of California doesn't trust Californian's to do the same.
But stereo is quite obsolete. There are numerous exciting multi channel options that render stereo "so 20th century".
I would say the whole point of stereo is to expand it to at the very least 5.1 if not a greater number of channels.
I got interested in multichannel two to three years ago and although the system is not yet setup I have already amassed a really wonderful collection
of source material.
I was interested in 5.1, (actually I made it 6.2) back in 1990. I quit with it in 2001. And have been doing 2.2 & 4.2 (quadraphonic .2 since).
I also have not owned a TV since 2007.
All I can say is that:
Some people who wander and stray are not lost.
They just have a different way. You do you & I do me. (Is my attitude).
This does not mean I do not appreciate your way or how much you have accomplished with your way (because I do). On the other hand, I would also not try to change you to my way. Because each persons way is their own way.
I am pretty sure that those of us on this site, while we aspire to be better in our own way, also know the different way's that we did not chose and have our own reasons for choosing the way we are enjoying this musical journey.
Some measurements of Revival Audio Atalante 5, google translate can't translate the web page:
I should mention Erin reviewed also, with NFS measurements. Good drivers w/r/t distortion, especially the midrange (~450hz-3500hz), but integration and cabinet design is... not great, I would say- though I'll note the surprisingly minimal directivity error between woofer and tweeter. Looks like a lot of the weirdness is more due to the drivers not being flush to the baffle + the sharp corners everywhere.
IMO - this is an ATC 100 but executed worse.
