edc
- Joined
- Jan 1, 2025
- Messages
- 12
- Likes
- 28
Hi all, this is my second thread here, and I would like to know more about doing correct speaker measurements/spinoramas.
I have a few pairs of vintage speakers that I would like to do spinorama measurements of and post them here on ASR. I have a few questions about how to take accurate and relevant speaker measurements.
Here is a JBL L15 which I would like to measure correctly.
Some months ago I built a spinorama platform, that's shown on this post. The platform holds the speaker at a 2-meter height, and there is 2m sphere of clearance in all directions, the same applies to the microphone.
I've read the excellent guide written by napilopez (how-to-make-quasi-anechoic-speaker-measurements-spinoramas), and I've made my first spinoramas using REW and VituixCAD.
Gear I use:
Microphone: Dayton Audio EMM-6 + calibration file
48V mic interface: iRig Pre 2 + calibration together with the ADC & DAC
ADC & DAC: 2x Apple 3.5mm adapters, one used as input, and the second used as output (they both work at the same time if forced in headphone/headset mode)
Amplification: Fosi Audio V3 + 48V PSU
SPL meter, voltage/ohm meter, unfortunately, I don't have any way to measure impedance response.
Questions I have:
Gear I use:
Questions I have:
- How should the speaker be positioned on the spin platform? Should the center of rotation be the center of the drivers or the center of the cabinet? In the case of the JBL L15, the drivers are centered to each other, but they are offset on the baffle. Same question for the vertical position: should the center of rotation be the cabinet or the point between the tweeter & woofer?
- Should the front baffle of the speaker be aligned with the rotational point, or should the averaged voice-coil position be at the center of rotation? In the case of a coaxial / horn driver that has the driver deeper inside the cabinet compared to a dome tweeter mounted on a flat baffle.
- How should the microphone height position be decided relative to the driver arrangement? I'm assuming the mic should always be at the center of rotation, but what about the height, as this seems to influence the results the most? Is it ok to find the height (within reason / between drivers) that provides the smoothest response and go with that or is that biased?
- During sweeps, is it ok to power the speakers using 2.83V measured from the amp (400Hz), or is it better to have a standard SPL value for all speakers, eg 86dB?
- Is the 1-meter distance between the mic and speaker enough or should there be a 2-meter distance during the spin measurements?
- Considering a 5ms impulse window width in REW, is 64k sweep length enough for spins, and 256k enough for distortion measurements? What about for ARTA burst decay?
- Is it possible to measure "Instantaneous Compression" using regular equipment, or is there a need for a physical dedicated generator + analyzer? Same question for multitone distortion.
- What are other measurements that offer useful information about performance? Step response, group delay,...?
