fpitas
They have big horn speakers; I have big horn speakers. What's not to like?I think the idea is try to recreate the experience of the studio monitoring of the final mastered mix.
Good luck with that.
The frustrating thing is that he did make one enlightened point, that due to a high RF field a cable with a better shield and ferrite filter made a difference, which I think is quite feasible.
Personally, I think cable changes can have audible effects beyond placebo but where scientific reproducibility is challenging - namely contact oxidation/migration over time. Removing the contamination by just unplugging and replugging can make a difference, but it's difficult to develop a viable, non-laboratory method to measure the effect.
Full agree, that's what I said.Consequently, trying to recreate a 'live' experience at home is pretty much futile as few recordings have ever been made that way.
That's what's always referred to as the circle of confusion.I think the idea is try to recreate the experience of the studio monitoring of the final mastered mix.
Yes I agree. There's no magical property in wire or connectors.
What I obviously wasn't clear about is that I was talking about the degradation over time of electrical contacts due to humidity, contamination etc. There is plenty of scientific research in this area (mainly to do with degradation of switching contacts) and lots of measurements.
In a large studio with hundreds of patch cables and "break" sockets, contamination over longish periods can lead to noise and faults. This is quite common, and often a re-plug fixes the issue for a further period, but if not, cleaning the contacts resolved the problem. The point I was making above is - this effect would be difficult to setup as an experiment outside of a lab where contamination can be controlled. The change in resistance, and any semi-conduction impact is likely to require sensitive measurement gear and no-one has the time or patience to do this.
Many of us here assume that reported cable sound differences are due to cognitive biases or placebo. But I also think that there's a beneficial consequence of just unplugging the first cable and plugging in the second. A proper experiment would have three facets: 1) a test with the current cables in after being undisturbed for several months; 2) a test with the same cables after contact cleaning or just re-plugging; 3) a test with the new cables. Skipping the 2nd test is where the process is flawed.
Me either. But I do wish they had some minimal locking device at least like ethernet orI don't feel I need to 'unplug and replug' my HDMI cables if there's no glitches, do you?
NoI don't feel I need to 'unplug and replug' my digital e.g. HDMI cables if there's no glitches, do you? There's no in between stage where the glitch is barely audible/visible, then gets louder/more distinct. It's yes/no
NoAnd even with 'analog' cables, if you consider the language in claims of cable sound differences, does it comport with being caused by corrosion on the contacts?
But it changes nothing. Our Hooper merely excels at being wrong.
He aims to harness arguments and reasoning to serve some of his arbitrary subjective feelings and make them weigh as much as facts do. It's impossible. That's chasing rainbows.
I gave the example of live music,
but take any recording you want; some guys did it with their equipment and their ears, it can be Nosaj Thing, nothing live about it. What do you think, can you come close to what they made in their studio the same way I described with removing variables or by adding variables?
You are saying R2R Dacs sound exactly the same as delta Sigma dacs?
For a extra punch I like to combine Tylenol wityh X-strength Advil. It makes for some relaxation and better sleeps I think.
As veteran of 9 medical device startups with 6-7 sham or placebo arm studies, half the patients would get treatment but the other half would get be selected and not treated and followed as treated patient. With drugs they would get dose of sugar pills if on the sham side. Two important things to state here. Having the placebo data is only important if there is another group has some difference that is being measured. Second, If the patient knows that that they have 50-50 chance of getting the placebo it alters the outcome that less will have placebo effect or a unexpected benefit. Most studies that have a sham are double blind, that is, those administering and conducting the study do not know which patients got which treatment or anything about the patient until the data is analyzed. Telling someone who is expecting there to be difference and then not having one, tells you absolutely nothing except that people will try ascertain the difference or guess.I think you are being too dismissive. The phenomenon demonstrated by such a 'phantom switch' test has huge implications for audio evaluation.
But 'just' demonstrating that the 'placebo effect' results in an all but impossible belief here, doesn't seem to faze radical audio subjectivists. They simply dismiss it as something that they don't do.
Yes, these are called 'just noticeable differences' , they are standard part of psychoacoustics data independent of Floyd Toole, and they're beside my point. No one denies that audio gear can sound different.
a brief moment of clarity randomly tossed into the delusion/insanity......The frustrating thing is that he did make one enlightened point, that due to a high RF field a cable with a better shield and ferrite filter made a difference, which I think is quite feasible....
yep - that's a real thing - cleaning, checking the plating, burnishing TT patch bay's conn surfaces and 'normals' , oxidation mitigation - simply mandatory... I do it once a year here with well over 3000 conn points... takes a few days......There is plenty of scientific research in this area (mainly to do with degradation of switching contacts) and lots of measurements.
In a large studio with hundreds of patch cables and "break" sockets, contamination over longish periods can lead to noise and faults. This is quite common, and often a re-plug fixes the issue for a further period, but if not, cleaning the contacts resolved the problem....
the "walking dead" of vinyl do... it's quite well documented...To be fair…nobody lasts to the end of an endless thread…![]()
you caught him on the trailing edge of his serotonin uptake inhibitors... or he lost his haldol...Me, too. He wasn't exceptionally rational, either.
Jim
THAT^^^ is a real thing...I've read somewhere that this phenomenon is behind a lot, maybe most of "veils lifted" from cable upgrades. It's not that the cable was actually any better, it's that you finally broke up the (audibly harmful) layer of oxidation by moving your cables for the first time in 8 years.
It’s from the official OST, so yes.Is your avatar from Silent Hill?
Looks like killdozer was rightoh god here we go again
