Saidera
There has to be more dongles like these Meizus and Apples available across the world and not just online.
1. The PC->DUT->AP analyzer config used in this review wasn't set up properly, which resulted in increased high frequency noise, which will not be present when you use the Meizu Hifi with headphones.Does anyone know if this measures better from a MacBook Pro?
Using ER2SE I'm getting much more volume out of my MacBook headphone jack than the meizu dongle. Anyone know why? I highly doubt my MacBook headphone jack outputs over 2 Vrms.
-_-You need to trick the meizu into high impedance mode.
3.5mm to 3.5mm empty extension or adapter onto the meizu, plug into phone then plug iem into extension once recognised
It works exactly as advertised. With impedance sensing.-_-
what a joke. I need ANOTHER adapter to make this thing work as advertised...
"dynamic self-adaptive adjustment" hmmm
sadly nowhere in this review was the dynamic self-adaptive adjustment "feature" mentioned
I mean, "dynamic adaptive adjustment" isn't the most self-explanatory thing in the world, is it? Your point is clear and I obviously missed the fine print. Nothing I can do about it besides return the product.Can we all stop confusing "working as advertised" with "working as
You realise this review was not, in fact, an advertisement?
This might be off topic, but do you know where one can buy that Ugreen dongle? There seem to be some available on aliexpress, but they look slightly different and are packaged in a plastic pouch instead of a cardboard box, so I'm not sure if they're the same model.
here is the exact model that WolfX-700 tested: https://detail.tmall.com/item.htm?id=634513448049This might be off topic, but do you know where one can buy that Ugreen dongle? There seem to be some available on aliexpress, but they look slightly different and are packaged in a plastic pouch instead of a cardboard box, so I'm not sure if they're the same model.
What issues are you referring to exactly? The rising high frequency noise or the low output voltage?Back on topic tho, should I expect similar performance issues when using this dongle as DAC with a mains-powered devices, like a PC or Raspberry Pi streamer?
the conversation about that is literally two messages above mine.What low output voltage? Amir's measurement show 2V, and he specifically comments on that
I'm talking about the noise.What issues are you referring to exactly? The rising high frequency noise or the low output voltage?
As long as you're not using an Audio Precision APx555 Audio Analyzer, you should not expect similar high frequency noise.I'm talking about the noise.
Oh, I didn't expect the problem to be so specific, lol. Thanks.As long as you're not using an Audio Precision APx555 Audio Analyzer, you should not expect similar high frequency noise.
