Unless someone corrects me, I don't think you can plug a headphone+mic and expect the mic to work on the meizu, no.1) Using with windows 10, can anyone comment on how clean the microphone input is on the Meizu Pro?
For that you'd need a SB G6 or Schiit Hel which has a dedicated mic input.
Gents, I have bought this finally. HiRes of any sampling rate on BubbleUPnP stutters where as 16/44.1 plays fine. Hi-Fi Cast plays HiRes with no issues but it doesn't support streaming services. Qobuz app doesn't have stutter issues with HiRes either but limits the sampling rate to 48 kHz as it doesn't support bit perfect playback.
What apps are you using? Thanks!
Might get a black mark for linking to Headfi, and its obviously just a user review not manufacturer spec, but seems to suggest will take mic and phones?
https://www.head-fi.org/showcase/meizu-hifi-pro.24225/
But I have never ever tried to use a mic with anything.
But in the back of my mind I thought I recalled reading the non pro taking a mic and the pro not doing so.
Thanks Jimbo. Don't suppose you have a random headset lying around from perhaps a phone purchase that you could try this with?
The Sonata HD supports microphone in and the Sonata HD Pro doesn't, wonder if that's where you're getting it from?
EDIT:
https://hifigo.com/blogs/review/meizu-hifi-pro-dac-amplifier-teardown-hifigo
"When the sleeve is removed from the 3.5mm connector, three metal shrapnel pieces are inside, allowing the four-piece headset to use a microphone and wire control. "
Seems like it physically does, but again no actual comments on if it works.
Now, I do. But old wired apple ones with the in line mic. FWIW , the mic doesnt work through the meizu on a phone call. I assume thats the meizu not an incompatibility with Apple stuff. the buds have a 4 pole 3.5mm.
I guess they mean it will play music/ sound out of the meizu even if you plug a 4 pole in. But then doesnt everything?!
I'll try in a bitThanks for checking. how about when connected to a PC, does it show as an audio input device and work on that? That would rule out the apple incompatibility concern.
Great news!Yeah, shows as input device when plugged into windows 10. The little test bar shows signal coming in too.
Ali express, from the meizu store there. Free postage. I'm UK too. Cost either 35 or 45 all done (on offer for one). Took week or 2 deliveryGreat news!
Now, how do I get one in the UK without waiting 2 months for it to come from China for double the price it should be....
https://m.aliexpress.com/item/40001...er_id=98e8780fecf449fda1246dde40939e6b&is_c=YGreat news!
