- Joined
- Oct 25, 2019
- Messages
- 11,111
- Likes
- 14,774
I'm sure it is a teensy tiny bit better.
3 letters and £10 to £30 better. For sure.
I bet you bought the xDuoo XD05 because it said 'Plus'.
Nope, even more pathetic than that... special "Black" version.I bet you bought the xDuoo XD05 because it said 'Plus'.
I shall give it a go and let you know. Interestingly that's how I started off, need to do a back to backwhen you do the cable hack to force meizu hifi to in high impedance on a low impedance iem, is the sound different compared to low impedance mode ( volme adjusted to be equal) ? i bought this dac for 43 ohms spring1 that was supposed to need power to shine but in the end this dac in low impedance mode spits half the power of my macbook internal dac , so this seems kind of useless for my need
sonata hd pro has hardware volume buttons and dsd256 (native but not dop) that meizu does not have but meizu hifi pro is smaller and support a mic or inline remote as it is trrs jack vs trs only jack for tempotecbetween Meizu hifi pro vs Tempotec sonata hd pro which better ?
what's the difference ?
How come the maximum possible volume is much lower on my AKG N5005's than my Sony XBA-N3's with the Hifi Pro? Looking at the specs, shouldn't it be the other way around? The 5005's goes quite loud at max volume, but the N3's would deafen me.
what is the exact condition to switch to high impedance mode ?(my 43 ohms spring1 is in low imp but my 150 ohms hd58x is in high imp )Neither would kick the Meizu intio high impedance mode.
I just got the Meizu Pro. It has a lot more power than the apple dongle. For my tin t2s running on my oneplus 7t, I lowered my volume by probably more than 25%. I was able to easily run my Focal Elex which fixed my general Android low volume problem. The Sennheiser 6XX is very near maxed out to get a decently loud volume. So if some songs are very quiet or mastered with low volume, it might be an issue for the 6XX still, but most everything was playing plenty loud. The Meizu does get a little warm vs the apple dongle which doesn't seem to get warm at all.
It does seem to drain the battery more quickly. If I need to last on one charge all day, I will probably use the apple dongle with my t2s since it can power them fine with a higher volume. But for listening to my full sized headphones, the Meizu Pro is really good. The sound is great. The Elex is still punchy and feels powerful.
Thanks for the info. I was just looking to see if it could crank out some extra volume compared to headphone ports on laptops, as well as the improved fidelity.
Had a look and it seems to be the real deal. [Edit: non-Pro Meizu is off the table] Considering the 9038S is £63 and the Meizu Pro £30 that becomes a tougher choice. If "approaching endgame" sound quality is only £67 as one review describes it, perhaps it's worth investing in the 9038S.
I have to return the used HD25s I got, as one ear has a lower volume. Thinking of exchanging for something else like Beyerdynamic DT1350 or Koss SP330/Pro4S. What's your take on the HD25s - best reasonably portable over-ear cans you've found as of yet?
They're not really my favorite, but they are built to last no doubt. Unfortunately a byproduct of that design is you can't replace the cables, so no 9038S in our future. I got them for my wife after she killed off a set 2 sets of W40's and a pair of SE535's with her 2 hour gym routine (sweat/moisture) but the HD25 is still running strong.
They seem quite bright to me, but I'm not a prolific headphone researcher like many here so it's probable my frame of reference is skewed given I only use IEMs. What did you go with in the end?
For Android? USB Audio Player Pro (UAPP)- free trial and around $5 paid. Brilliant app. Bit perfect, supports MQA, Tidal and lossless. Overcomes Android volume limits and resampling.
, felt the sameYou must really love your wife a lot, and I mean a lot or be really wealthy.
You must really love your wife a lot, and I mean a lot or be really wealthy. Both pairs are on the pricey side of things to me
Hi,
I can see it was questioned a couple of posts up and wasnt sure if there is an answer, 'can I use USB Android Player Pro with Spotify' ?' on Android ?
All my listening on my Redmi note 8 is done through Spotify and the headphone jack is quite poor. If I buy a dongle (any dongle) can I use UAPP with Spotify ? According to the links below, you can't (I think). Does that mean my audio won't be that much better than the headphone jack I am using ? Or just that I won't get the full potential ? Note that my phone is rooted
https://www.head-fi.org/threads/using-dac-with-spotify-on-android.908205/
https://forum.xda-developers.com/oneplus-3/help/external-dac-spotify-root-solution-t3886722
