You could do a swept tone (single vibration frequency, though suppose you'd also have to define the axis of the force applied). Applying high-level white noise to a speaker would fry tweeters, but for your test system I don't think anyone really cares. The main point I and others are making is that, to be relevant to audio, you should look at the audio output of the device under test. You could then build a set of plots for different devices showing their relative sensitivity (or resistance) to vibration, and demonstrate how your product reduces that sensitivity. That is an engineering, not audiophile, approach, but would provide a simple comparison for lay folk.Well, actually it would be quite possible for us to test devices in such way. We once had an industrial client, who was considering to use our isolator for their products. But they wanted to be sure that the final result is in agreement with required specifications. Therefore he gave us the vibration spectrum that was measured at the clients floor, and we should show how our isolator would perform in such condition.
In order to make these measurements, we had to develop our own shaker, and control the vibrations in such a way, that it generates the same spectrum (given in one-third terz band amplitudes) as at the clients place. Then we placed our isolator on top of that shaker, and we could measure how the isolated spectrum would look like.
Reproducing a vibration spectrum with coloured noise is much more challenging than for example just outputting white noise, or some harmonic vibration, which could also be done by it.
Do I understand your intention correctly, and would this help you with your tests when placing the different equipment on top?
Note I would not be doing this testing; my current day job is a different world than audio (or aerospace).
It would be cool to show that the audio band is covered, though then you'd have to show the frequency response of your shaker. I've been trying to think back and frankly have no idea how high our shaker went; it was higher than I expected, but I just can't recall how high. I remember discussing it with several engineers and how large vibration modes could be generated along with ultrasonic waves through the airframe and such. I no longer work on flight HW; sometimes miss it, but after the design phase was over, testing and handling all the real-world brutality was a PITA.one additional remark that might be interesting, and maybe relevant in this context:
if we used a wav-file of some music recording, and send this as the control signal to our shaker, we could actually hear that music, since the plate of the shaker acted like a microphone. That proves our shaker also works in the audible frequency range, and the amplitudes could be adjusted from extremely small to rather large ones.
For the record, I really appreciate your insights into this, and seeing the results of this sort of testing would be of great interest to me (and probably many others).
