I can implement this if folks are OK with it.Actually, CEA-490-A-R2008, the successor to IHF-A-202, only states
1k is better than nothing but realistically still inadequate.
Yeah, unfortunately. OPA1612 would be probably good for MC but definitely not for MM preamp. OPA627 is obsolete and expensive, I agree. However, still technically excellent. I am sure that good replacement with same resulting parameters would be OPA165x series.
Thank you for your very informative measurements PMA.
Any interest in testing LT1028 noise ? It seems a popular AOP among audiophile RIAA MM DIY projects ...
Greetings,
I don't roll OPAs in general but the LT1028 mounted on a DIP8 socket is available from Audiophonics France for 8,90 Euro incl. Tax a piece. And it is on stock there: I wouldn't call it expensive in the grand scheme of things...Thanks for your question. I made a similar set of measurements back in 2008, LT1028 was probably the best performing bipolar input opamp in MM phono pre those days. It has very low voltage noise and low current noise (for a bipolar opamp)
In = 1pA/rt(Hz), which is 2.4x better than the ADA4898 in my test and 1.7x better than OPA1612 in Fosi X5. You might expect similar result (above 2kHz) as with LM6171 here. This would be a considerable improvement from ADA4898 or OPA1612 and a good candidate even for the MM preamp. The part is very expensive and unfortunately I have no more of them in stock. In 2008, I used it for a commercial MC phono preamp design and also for a balanced input MC preamp design.
Thanks for the info. I may add it to my next purchase at Audiophonics. Back in 2008 I bought those parts at about $50 per piece.LT1028 mounted on a DIP8 socket is available from Audiophonics France for 8,90 Euro incl. Tax a piece.
About the same price at DigiKey too,14.60-21.45 EUR depending the type.Thanks for the info. I may add it to my next purchase at Audiophonics. Back in 2008 I bought those parts at about $50 per piece.
Interestingly enough, the price is 19.73 EUR (w/o VAT) at Mouser:
So, still expensive. I prefer reliable suppliers to prevent fake opamps delivery.
@Audiophonics is a member here, so I hope they chime in to solve the riddle....About the same price at DigiKey too,14.60-21.45 EUR depending the type.
There's something wrong with Audiophonics.
classic 5534an (or opa604, 1611) ?Comparison of simulated and measured output noise density and total output noise for several op-amps in the Openamp phono pre. Shure M35X cartridge is at the input. Please note good correspondence of simulated and measured results. Please also note the dominant role of the input current noise density at higher frequencies.
the list would become a little exhaustive in the "more classic" ones ;-)
is extremely suspicious. They sell 2 x LT1028 in SMD/DIP adapter for half price of the single piece. I do not believe they are from genuine source.the LT1028 mounted on a DIP8 socket is available from Audiophonics France for 8,90 Euro incl. Tax a piece.
I doubt it for the 604/ probably better134 here ... but it was just to be exhaustive and that in general we have them in the drawersI will maybe find 5534 in my stock. It will be quite good. I need to simulate loop gain stability with 5534 first. I had to add FB compensation for AD797 and LT1028.
OPA604 will be a bit worse than OPA134, no need to test, and I do not have it.
The list will be updated. And I can only test single opamps in DIP8 packages, or with a SMD/DIP adapter.
BTW, this:
Thanks a lot @pma!Comparison of simulated and measured output noise density and total output noise.
- once the needle hits the ground all noise from the pre is drown in the surface noise of the record anyway
Yes I will. I found 2 pcs of NE5534 in my stock. They should be good because of their quite low current noise. I think that SNR with cartridge should be at least 70 dB not to affect the best vinyl presses. SNR calculated as 20log(500mV)/total noise). 500mV as 5mV x 100 (Openamp gain at 1kHz).In regard to the panel I would suggest, again, to add at least the general purpose NE5534, or NE5532 respectively. And reiterated, the self-noise of the pickup assembly may be worth a consideration:
