Resistive Loading SUT or Nah?
Yes, but if I keep the source resistance close to the nominal tap values (3 and 40 ohm) in my Denon AU-320 it is very flat.
Using 10 ohm source on 40 ohm tap gives an overshoot…
The bump below 100hz seems to be a measuring artifact when using the oscilloscope, not there when I use other methods
img_5311-png.1068568
With a Zobel I can correct the overshoot, I cannot really hear any difference…For maximum flatness and extension I need to allow a small overshoot on my Oscilloscope..
1724859235923-png.1051517
Is this with the transformer cabled to the input of your phono stage? Where is your measurement point?
One thing to be careful of is that you use a 10x probe on the 'scope; the 1x can really load things down.
Function generator-voltage divider- SUT-RIAA load with 47k and Capacitance 50pF , Oscilloscope connected in paralell with probe at 10x , I think you taught me that once…
measurement point at RIAA input see photo , Denon AU-320 has fixed cable to RIAA
I have used both Dummy Load 47k + 150pF and RIAA, not sure what I used for that particular plot.Most likely dummy load For sure RIAA load in this plot.
MM carts and 400-500mH are irrelevant here as MM do not need or use SUT. My MC have 25uH and works fine with a suitable SUT or properly tuned Zobel/RC load, can even do it with secondary R tuning alone , but with some ultrasonic frequency loss.
