Good suggestion, researched that one as well. Unfortunately it doesn’t have proper LFE channel processingNAD M10 V2. You might have to drop the center.
Unfortunately Onkyo has only one sub channel (replicated) while cinema 50 has 4 independent sub output. Making the right Candidate for DiracLive bass management.So the Onkyo RZ50 includes DIRAC for no additional cost and it's working today. Or you can buy the Denon X3800H/Marantz C50 for $1,000 more then spend another $350 in March to get DIRAC. Ooh, and maybe another $500 in 2024 to get multisub support.
Martin
Are you referring to the Cinema 50? If so these are available, plus Stereo which scrolled offscreen:Hello!
When you connect the AVR to a PC, what channel configurations are available? Only 7.1? Or also for example 9.4? thx
I assume you want to create surround PCM sound from the PC to send to the Cinema 50. I believe you can send 5.1 or 7.1 PCM via HDMI, but PC does not support 5.2 since there is no way to address 2 subwoofers in PCM.Thank you @18000rpm !
I am asking because I would like to understand if I can create a 5.2 signal on the PC and send it "as is" over HDMI to the Cinema 50, put in direct mode (I think this is the name of the mode in which the signal is not further processed by the AVR).
This procedure would be, in my expectations, an alternative to the missing analog multichannel input.
Alright, thanks. So best to not upgrade right now.You'll loose your license because it is binded to the MAC addresses of the avr. The "serial number" of its ethernet port.
Ah thanks @peng! Will do!
That is good news in case of a default unit.Hi,
I'm posting the answer here as well as it can be of interest to others:
If your Cinema 50 will be replaced by another Cinema 50 there is no problem, just email us at [email protected] and we'll reset your license so that you'll be able to use it with the replacement AVR.
Please take into account that the license is intended for a specific device... if you'll sell your Cinema 50 you can sell the license with it and we'll assist you with the account and email for your buyer but you cannot use that license for another model.
No, the license isn't lost... it's the same as with Onkyo or Pioneer, the license is associated with the AVR and follows it.That is good news in case of a default unit.
But if someone sell the unit, the license is lost.
At least this is what I understand
Exactly, so you lost the license.No, the license isn't lost... it's the same as with Onkyo or Pioneer, the license is associated with the AVR and follows it.
It's the owner that changes (on approval by the seller) when the AVR is sold.
I'd choose the second option...Exactly, so you lost the license.
Or you have charge the cost of the license on the value of the avr. So you could buy another one for your new avr
I hope you find someone who appreciates the license. But I guess it will be easier than trying to get a discounted avr+ licenseI'd choose the second option...
If you want a high quality streaming solution, then I would say none of those listed. For a solid streaming experience, I recommend investing in a Roon server and/or a BluOS enabled streamer like the Bluesound Node.I have a question for those who had TX-RZ50/VSX-LX505 and also Denon3800, 4800/Marantz Cinema50,40.
Which of these receivers is a better, more intuitive and sonically/technically better streamer? I'm mainly interested in Spotify, Amazon Music HD, internet radios and a home archive of recordings on a NAS server or USB stick.
