raybies
- Joined
- Jun 29, 2021
- Messages
- 9
- Likes
- 4
No it's Dirac.Is this part of Audyssey Pro? Where do you find curves?
To avoid confusion, if you meant the latest Audyssey version, it is the Mult EQ-X, the Audyssey Pro is the very old version from n years ago.Is this part of Audyssey Pro? Where do you find curves?
Answering my own question: Your enter the name of the receiver eg: CINEMA 50Does anyone know what you can do in the Advanced menu of the web UI?
I can check disabling that and report back.
You are absolutely correct. Disabling Dynamic EQ in Audessy, it seems to be DIRAC is bit better(especially bass and vocal).This is important because I don't think DIRAC makes use of Dynamic EQ setting at all (and possibly why movie tracks sound "better" w/Audyssey).
In this hobby, I suppose it is hard to get consensus on most things. Personally, I think the numbers/graphics show this AVR is very good, but not the best for sure. For the KLH Model Three, if you sit not too far, and don't listen too loud then you will be fine with the Cinema 50.Apologoes, I'm new to this and still very confused by the graphics and the detailed information. What would be the consensus for this AVR? Is it generally positive or negative? I'm looking for AVRs since I'll be watching movies and listening to music, but I don't have the budget for separate electronics. I'm thinking of pairing this with KLH Model Three.
Thanks!
link pleaseSTEREO magazine measurements for C50:
@4ohms, stereo, 1% THD: 32W per channel
@4ohms, multi-ch, 1% THD: 32W per channel
@4ohms, Impulse power, 1kHz: 42W
Such numbers are useless unless more detailed test condtions are included, not just 4 ohms 1%...so I would just ignore it.link please
Looks like some HEOS changes as well as some Dirac bug fixes:Just received firmware update on my Cinema 50, to version 8300-8213-D012-9710
Anyone know what changed?
If you use it with Audyssey or Dirac Live, you can expect improvements.I am using PM6007 with Polk R200 (mainly 2 channel audio). Would there be improvements if I upgrade to the cinema 50, or would I be wasting the processing and amplification of the cinema 50 by just using it for 2 channe
And you might even get themIf you use it with Audyssey or Dirac Live, you can expect improvements.
I meant to say might, or could, "can" was a mistake.And you might even get them
I recommend after measurements using REW and it is ok to not like the results, regardless of what the predictive graphs report.
- Rich
