At first: You need to determine Your needs If not, it's all speculation.
Examples:
- Want to go on with amps used now, You need more amps and an active crossover in front of it for that
- Want to go for multi-channel-amp, skip Your amp and use that, if sufficient filtering is provided
- use plate amps with integrated DSP for filters and skip (sell) Your amps
For me the latter is what I do.
And if You want to build on Your own: put the bass on left and right (opposite), choose a driver with low fs and Vas (what will mean low SPL) for closed cabinets, what means smaller enclosures, or do some science experiments using software (that gives some narrow approximation, but never the result as reality measurements will provide).
Crossover with LR4 at 100-120Hz and 3500-5000 Hz rsp. , depending on driver's capability, should do the job, besides DPL approximation, if necessary.
Just the frame ....
Examples:
Just the frame ....
