make the khadas diy case ok with tone board without vim board(sigh...post in wrong board twice, here is right)
wyrainer
hi, everyone, sorry for my poor English
If you can't understand my word, please see the picture, I think this is very easy
my tone board is vim edition, if yours is generic edition, your case should be less high, because 40 pinheader is not on board
first you should buy more different lenght standoffs
because this case was not designed for tone board, you must cut off one side of khadas diy case, otherwise the rca and usb port can't come out
at last install tone board into this case
I'd call this more of a frame than a case, but an interesting take on enclosing the tone board.
yes, I agree with you.
I am making a 3d printable part, it can be used with this diy case.
after that, it maybe become a case.
I've also a Khadas Tone Board, Vim edition...
wyrainer, thank's a lot for share us your efforts in order
to make a proper enclosure....to this little great DAC.
I keep in mind adapt to it an commercial aluminum box,
sure your 3d printable schemme ...could help me.
So you can use the tone board only as a dac? It just needs a case. What other cases are out there. I'm considering this for my first semi diy and have no idea what to look into.
I did mostly the same with the AUD 8.00 case for the VIM. This will be temporary though; I am still looking for a permanent solution. I don’t want to pay shipping for the BEX aluminum case from America to Perth, too expensive. I am still looking for a locally sourced solution.
Yes, you can use the Khadas tone board (generic edition or Vim edition) alone as USB DAC
attached to a computer: VIM or other single board computer, pc, etc...
https://forum.khadas.com/t/question-about-tone-board-generic-edition/2580
I've just bought mine keeping in mind attach it, with a case,... to my pc,
but perhaps to a single board (Vim2 as next purchase, or my actual Asus Tinker Board -S)
as I2S DAC without needs about solder extra parts.
@Mistic @ILovePhonon
3D model of MiddlePart is almost done, this diy part cooperates with khadas case(top plate and bottom plate)
its size is for vims edition.
if your tone board is generic edition, you can use it, but it is little bigger
I must print one to check if somethin is wrong
I have not a 3d printer, but I find a company, it can print it for me.
two or three days later maybe I can tell you result
This is great!
3D printable case is done.
but made a little mistake, I have to correct it, and print a new one
When I get the new one, I want to paint it red or golden, but i don't know which color is more beautiful
I'm running this same setup. D10 > KTB and it's fantastic.
I did mostly the same with the AUD 8.00 case for the VIM. This will be temporary though; I am still looking for a permanent solution. I don’t want to pay shipping for the BEX aluminum case from America to Perth, too expensive. I am still looking for a locally sourced solution.View attachment 17923View attachment 17924View attachment 17915
How do you take the standoffs out of the DIY case to remove the middle portion? These screws seem hard to get out.
