Building Valeria: A Compact Horn-Loaded Speaker
Aijan
I’ve been using a pair of KEF LS50 Metas as my front speakers and my DIY KEF LS50 clone as the center channel speaker in my home theater for a while now. I’ve been generally happy with the smooth sound they produce, but there’s one thing lacking: dynamics.
Granted, these are small bookshelf speakers, but they receive assistance from my DIY subwoofers, so they don’t have to reproduce the most difficult frequencies of all: sub-bass. Unfortunately, at my listening distance of approximately 3.5 meters (~11.5 feet), they start to distort noticeably at higher volumes, which reduces the impact of certain movies, especially ones with epic soundtracks.
Lately, I’ve been thinking about building high-sensitivity speakers using pro-audio drivers. Coming from coaxial speakers, where the tweeter is located at the center of the mid-bass driver like the KEFs, my main goal, apart from improved dynamics, is to achieve decent vertical directivity.
After doing some research, I came across small horns like the 13 cm (~5") B&C ME10 and a relatively high output 6.5" mid-bass driver: Lavoce WSF061.52. By using physically small components, a driver center-to-center spacing of 16 cm (~6.3") that corresponds to about 3/4 wavelength distance at the crossover frequency turned out to be possible. You can reduce the distance even more if you’re willing to mount the mid-bass driver from the inside, but 16 cm is good enough for me.
The only problem left is that the mid-bass driver’s frequency response takes a nosedive starting around 120 Hz, even after adding a port. No problem, though – I have multiple subwoofers with dual 12" drivers for low-bass duty.
I designed a compact cabinet with internal bracing that touches the drivers, making the drivers part of the brace and reinforcing the front and rear sides of the cabinet.
I cut the pieces on my CNC router using 18 mm (~3/4") MDF and then added 45-degree bevels to all sides on my router table. I also added a 6 mm MDF backing to the front baffle to make it stronger. The pieces are simple enough that they can be cut with a circular saw or jigsaw, and the holes can be cut with a handheld router.
Borrowing an idea from KEF, just like in my KEF LS50 clone build, I attached the braces to the walls with 3M VHB tape instead of regular wood glue. The soft layer in between acts as constrained-layer damping to reduce resonances.
I glued the port, made out of a plastic water pipe (5.7 cm inner diameter), to the back wall with hot glue. The port is quite short (only 3 cm, not counting the outside MDF flare). The crossover board is installed on the side wall with standoffs. I placed M4 threaded inserts into the front baffle so that I could remove and install the drivers as many times as needed without having to worry about stripping the holes, which is all too easy with MDF.
I was originally going to use an active crossover, but after doing a few simulations in VituixCAD, I noticed that a simple passive crossover with only five parts would work nicely. I used a second-order crossover (a 2.5 mH laminated steel core inductor in series and a 15 uF capacitor in parallel) for the mid-bass driver. For the compression driver, I used a first-order crossover (a 3.3 uF capacitor in series) and an L-pad circuit (two 4.7 ohm resistors in series/parallel) to reduce its level and flatten the response. You wouldn’t normally use a first-order crossover with compression drivers, but once again we are going to use it in a home environment where it will unlikely to be stressed, and besides, the electrical roll-off starts quite early. Finally, the compression driver is connected in reverse polarity to avoid a dip in the frequency response at the crossover frequency.
I patched the rough spots on the cabinet with wood filler, sanded it smooth, and applied 19 mm (3/4") roundovers to all sides on my router table. Then I took the speaker outside and painted it with several coats of MDF primer using a spray gun. Once the primer had dried, I sprayed several coats of top coat (steel blue). Since I was using water-based paints, I added some paint conditioner (pouring medium) to help reduce orange peel.
Once the paint had dried, it was time to add absorption material to deal with the standing waves that would form inside the cabinet. I lined the walls with felt (5 to 10 mm thick) and placed extra-thick 60 mm pyramid foam on top, leaving enough space for the drivers, of course.
Here’s the side view of the cabinet with drivers waiting to be mounted. The mid-bass driver, Lavoce WSF061.52, has a 1.5" voice coil and a paper cone, while the compression driver, Lavoce DF10.142LM, has a 1.4" voice coil and a polyester (likely Mylar) diaphragm.
Finally, Valeria is complete standing next to one of my KEF LS50 Metas. They’re roughly similar in size. Valeria’s dimensions are 19 x 33 x 22.5 cm (WxHxD), while the KEF LS50 Meta is 20 x 30 x 28 cm (WxHxD).
So, how does it sound? By itself, the bass is anemic, as expected. However, as soon as you add a subwoofer to the mix, this little speaker transforms into something special. Female vocals are particularly lifelike, thanks to the effortless dynamics and silky smooth sound of the compression driver. With tracks like ‘Can’t Catch Me Now’ by Olivia Rodrigo, I found myself turning up the volume higher and higher, yet the sound remained clean throughout.
Valeria really shines at high volumes. In fact, on some bass-heavy tracks, I discovered bass resonances in my room that I hadn’t noticed before. With the LS50 Metas, I couldn’t turn the volume up that high without seriously distorting the sound.
Now, some measurements… The average sensitivity (300 Hz-3,000 Hz) is 93 dB/2.83V/1m, measured with a UMIK-1 microphone. This means that only 1 to 2 Watts of amplifier power is needed to achieve very loud volumes at 1 meter from the speaker.
The impedance plot looks relatively clean, with the exception of a resonance at around 950 Hz. How audible this is, it’s hard to say. The nominal impedance is 8 ohms, and the worst-case EPDR (Equivalent Peak Dissipation Resistance) is around 3 ohms at 200 Hz, making Valeria a relatively easy load for the partnering amplifier, as John Atkinson would say.
The frequency response is mostly within ±3 dB from 120 to 20,000 Hz (quasi-anechoic measurement). The mid-bass to compression driver crossover frequency is 1.6 kHz. As for the subwoofer crossover frequency, 120 Hz looks like a good starting point. You can probably go a bit lower if you place the speaker close to walls, as this will result in some bass boost from nearby boundaries. It’s also a good idea to run the subwoofer(s) a few dBs hot for optimal integration.
The horizontal directivity is ±45 degrees nominal, but starts to narrow gradually above 3.5 kHz. Thanks to the smooth directivity, the frequency response can be equalized without any ill effects.
It’s surprising how a small speaker like this one can get so loud yet manage to stay so clean. The trade-off, of course, is little to no low-bass output by itself, but that’s precisely what subwoofers are for.
Please let me know what you think.
Subjectively how much more narrow is the horn's dispersion vs the Coxial's? I am just curious how much more room sound you get from the KEF compared to the horn...?
or better still if you have a directivity polar plot for the KEF as well...?
What kind of jig did you use to measure impedance in REW?
Amir measured the KEF LS50 Meta here.
That is an interesting idea! I had some very old double sided tape, it was still intact. But not sticky. I wonder in the long run if the strips would de-adhere?
It appears you are porting around 100 Hz, if you ever have a chance I'd be very curious how it measures with the port blocked.
I could see building a shallower but taller version of these for a particular application...but I need someone to make the cabinets, I don't have to tools (or time) any more...
It appears from the drawing that the horn/driver combined depth is about 150mm?
You might want to use at least 1 mm thick foam tape, like 3M's VHB line. Personally, I wouldn’t risk using old tape.
The original frequency response posted above doesn't fully account for the baffle's effect, so the bass response looks better than it actually is. For that reason, I wouldn't recommend a sealed design, as the roll-off will likely be too steep.
I’d also recommend loosely placing some open-cell foam in the throat of the horn to smooth out the frequency response. My final measurement, with the foam plug in place and the bass response corrected, is shown below:
The combined depth of the horn and driver is approximately 130 mm, so a shallow cabinet is certainly possible.
It might be OK...my current idea is with like 6 in-wall subwoofers behind a large TV due to aesthetics/wife. Ideally maybe I can find like 10" or 12" grille and use actual woofers, then the crossover to the satellites could be like 200 Hz or whatever.
Very nice project, I really like the choice of chassis and the cabinet. Thumbs up
Have you ever tried to stay with coax?
I always had man-sized speakers and wanted the same performance in a smaller space, so I coupled two PA 8" coax from B&C to an 80 Hz bass reflex cabinet with an active 18" Beyma.
You can only see the satellites and the maximum undistorted volume of the system is close to the original concert.
I wish you every success with all your future projects.
Thank you so much for your kind words! They’re much appreciated.
I had though about using coaxial PA speakers, but I couldn’t find one with a good frequency response.
Very nice speaker build! I’d love to see a build thread and some measurements. I especially liked the compact cabinet and the flush-mounted rear access panel. Keep up the great work!
I looked again, but I can no longer find the measurements.
They are on some USB stick. The final tuning was a few years ago. I tuned them pretty linear from 80hz. The active 18" Beyma subwoofer takes over the range up to 80hz.
The omnidirectional behavior of this B&C coax is very good, probably because the small horn has a large opening angle.
I make any changes to the listening position with the DEQ2496 or, not so long ago, with the WiiM Ultra.
