I own a set of LRS+ maggies. Very pleased with them, but could somebody explain to me why the buttons on the left speaker differ from the right?
The buttons (or “tie-downs” in Magnepan parlance) that clamp the diaphragm at different locations, are placed there to both damp the fundamental resonance and create a redistributed group of resonances to passively, self-equalize, or enhance the output of the frequencies between the dipole baffle cutoff frequency and the lowest resonant frequency.
Any open baffle, dipole loudspeaker without this approach, and a driver with a “Q” of 0.707 or less, will have a first order (6dB/octave) high pass characteristic from the baffle cutoff frequency down to the fundamental resonant frequency, below which it will fall at 18dB/octave. Alternatively, most dipole film loudspeakers, such as an ESL or planar magnetic, will often have a singular high “Q” peak at the fundamental resonance with a droop in the amplitude response between the fundamental resonance and its baffle cutoff frequency.
While all the current Magneplanars use the distributed mode approach with symmetrical positions and button count on the left and right loudspeaker, the LRS and LRS+ are unique among the Magneplanars in that the system pairs use asymmetrical “tie-down” buttons, with (most examples) having 1-button on one of the loudspeakers, and 3-buttons on the other loudspeaker, creating 2-distributed modes on the first and 4-distributed modes on the second loudspeaker, or a total of six interleaved modes of different frequencies. This is effective at allowing the pair, when working together, to produce smoother and deeper bass than either single unit alone.
This makes achieving an accurate, meaningful measurement, more difficult, particularly if the tester doesn't know they are different or doesn’t understand how and why they are different from each other. Almost everyone that has publically disclosed measurements of the LRS’s appear to be unaware of this design element and have just measured one of the two speakers, providing a misleading result.
I hope this helps clarify the issue.
- James Croft
