Will try the new firmware on my amp shortly
Just curious, those of you using bookshelf speakers and a sub, are you able to share your settings for high pass/low pass?
I have a pair of Revel Concerta2 M16 bookshelf speakers, and have recently added an SVS 3000 Micro subwoofer.
Initially I had the crossovers for both set at 80Hz (mains 4th order LR high pass @ 80Hz, and the sub 4th order LR low pass, also at 80Hz), and ran RoomPerfect). With this crossover I ended up with the subwoofer gain set quite low, to avoid boominess or muddy sounding bass. Bass output did seem pretty hefty all the same however.
I since read a few articles and forum posts saying that most beginners set the subwoofer crossover too high (80Hz being set as an example of this!), and the gain to low, and the low pass filter crossover should actually be much lower. I've seen a rule mentioned of it being 0.7 of the lowest frequency your main speakers can do (at -3dB). There is a Darko audio podcast where this is also suggested for ported speakers, and 0.6 for sealed speaekers.
In my case, Revel claim the following low frequency performance for my main speakers...
Low Frequency Extension 55Hz, 50Hz, 45Hz (-3 dB, -6 dB, -10 dB)
I've since tried the following settings, before running RoomPerfect again:
Mains high passed @ 55Hz, level 0dB
Subwoofer low passed @ 55Hz, level -3dB (with the -3dB taking it to the 0.7 point? Or should I be using 0.7 of 55Hz...38.5Hz seems very low to me?)
This now means I can turn the gain on the sub a lot more and it seems like the sub is doing a bit more than before, but I'm still not sure its quite right, and the bass is maybe a little less impressive overall......I find myself baffled by the theory and the possibilities which seem quite endless, although also impressed by the abilities of this little amplifier!
What are you folk with a sub and bookshelf speakers running? What would you recommend for my speakers and sub?
Many thanks,
Will
Are you definitely measuring to the speakers and sub per Lyngdorf's recommendations, i.e. from MLP to speaker tweeters, from MLP to the wall or corner behind the sub? Also, are you adding in the delay for your sub's DSP, e.g. typically 5-6ms for a SVS sub? This all being in place before running a RP calibration?
