TBone
- Joined
- Mar 16, 2016
- Messages
- 1,191
- Likes
- 348
In an attempt to study/adjust for proper high freq. tracking/stylus force & wear on my cartridge:
(no, I don't setup turntables using "ears" alone)
The following info is based on repeat passes using the STR100 CBS Lab disk, track 7B (R.ch. most inner groove), played 5 times, approx. 1 minute apart. Vertical tracking force (VTF) was changed per each pass with no attempt at adjusting speed in relation, hence the slight shift in frequencies (generally: greater VTF, the lower the freq). No change in stylus rake angle (SRA) was provided, however it should be noted that SRA does change based on VTF.
The stylus used is a Fitz Gyger FG-S; an aggressive line-contact type, similar to the Ortofon Replicant. This particular stylus profile was designed to be similar to a vinyl cutting head, therefore the potential to cut/damage records maybe higher when using aggressive profiles. Setup, esp. SRA & proper azimuth are critical to its performance.
Red = 1st pass,
Purple = 5th pass,
The dotted lines indicate respective crosstalk.
5khz ...
20khz ...
I have never put much stock that quick repeated playings damages grooves, however I do understand the potential.
PS. Amir, since a seperate vinyl/turntable section is not provided here, I dumped this into "Analog".
Red = 1st pass,
Purple = 5th pass,
5khz ...
20khz ...
