- Joined
- Jun 5, 2016
- Messages
- 2,886
- Likes
- 4,706
I'm looking for an amp that may well be a unicorn, but doesn't hurt to ask. The criteria are below, with detailed reasons why they are what they are following:
I've already ruled out a couple:
I also took out an individual woofer (the baffle is cleverly engineered; I think they even use the woofer magnets to hold the steel grille in place!) and measured it, which shows that despite the high impedance the woofers are wired in parallel (as was clear from viewing the wiring as well):
- Small - let's say outer bounds of 8.5" (i.e. half rack), 1 RU height (could be taller if it's attractive), and 12" depth
- Signal sensing turn-on
- High voltage swing for high power at high impedance: 600W into 8 Ohms would be very nice, but half that is likely fine. The matching amp (which I have but is too large to place anywhere useful to drive the sub) is rated 300W.
- High gain: give full output or close to it from a 1.2V unbalanced input
- Flat FR down low
- Either no fans or variable and quiet fans
- Cost significantly less than a second unit of the amp currently in use but that I will need to repurpose somewhere else in the near future, Powersoft Mezzo 604AD.
- Low impedance drive capability (see below)
- Frequency response load dependency
- Built-in DSP (will use Monoprice HTP-1 PEQ for any needed transform + DLBC for calibration)
- AudioControl Bijou 600. @amirm's review of the Rialto variant (they seem to be the same except for the case) showed LF behavior unsuitable for my use case, that correlated with Sound & Vision's measurements of the previous version.
- QSC SPA2-200. I have some positive history with the line (used the SPA4-100 model to run the height speakers in our old house), but SPA2-200 needs more input voltage than my source (JL Audio JLINK wireless receiver) can provide to get to full power.
- Parasound Zamp v3. Tried it. Need more voltage swing.
- Powersoft Mezzo 602A - power is right, cost while less than the fancy model (2 vs 4 channels, no Dante input) is still way too high for this use case. Also, I'm not even sure who distributes Powersoft in the US any more. I'm 99% sure I bought my 604AD from Full Compass, but they don't seem to carry the line any longer. I don't recognize the shops offering this amp that I see in a search (which isn't necessarily pro or con, just that they're not known to me).
