I have no idea about that stuff. My stuff is parametric equalizer (PEQ) for sound improvement.Thank you!
So on your screenshot there is presets for app working on jailbroken iPhone?
WiiM Pro has a built-in EQ.My apologies for the newbie question, as I'm getting interested in headphones again, but I don't know about doing the PEQ.
So, what would be the best (and inexpensive) way to use PEQ? I have a Denon AVRx4800h. I will be streaming through a WiiM Pro. I have a Mac laptop and an android Google Pixel 8 Pro phone. The phone would be running the Amazon Music Unlimited app for song choices. If using the laptop or the phone, how would I do the connection?
I do not want to use Bluetooth due to the loss of quality. I don't mind using long cords.
You have to drop some minor peaks and dips, but should be enough to get rid of the big ones.Yes I see... A four band PEQ. Will that be enough to do proper equalization? I don't need it perfect I just want to get it close
EDIT: please see my new thread for an updated version and instructions.For anyone else who has a Fiio device with PEQ support, here's a nodeJS script I just wrote that lets you convert Equalizer APO files (such as the ones at the start of this post). to Fiio xml files. You can then import them on https://fiiocontrol.fiio.com (I couldn't find an option to import on the mobile app though).
There are many Equalizer APO features the script doesn't support, I only did the filters that Fiio control natively supports. (in particular they require a Q value, instead of a BW or slope).
node convert.js.txt <input APO filename> <output xml filename> (the input defaults to stdin, and output defaults to stdout).So others don't waste their time doing this as well, I can confirm that Amir's target are just the Harman targets.Ha! Just so happens I'm doing that, for another reason. Yep. Sounds good.![]()
Heres the file autoeq uses: https://raw.githubusercontent.com/j...heads/master/targets/Harman over-ear 2018.csvIs it possible to download Harman over-ear target? On Hangout I can only found in-ear targets.
Thank you!
If I was a musician I certainly would be insulted if you did this to my music. Also this would take an absurd amount of time...Real acoustic connoisseurs have separate EQ for every single track in their library.
I know thats why i listen without EQ. Neutral headphones, closest to the way it was mastered. Acoustic is slang for another thing but we dont do that here.If I was a musician I certainly would be insulted if you did this to my music. Also this would take an absurd amount of time...
