KRAKATOA Quintuple 18" Point Source Full Range
Neale
Perth, Australia
... in the spirit of ASR fun, for those looking for an active full range speaker, a new one just released:
https://www.bassboss.com/catalog/krakatoa-quintuple-18-powered-point-source
  • 4-Way quintuple 18” powered co-axial point source full range
  • Full-Range single axis point source. Vented short-horn (6th order) low frequency section, co-axially positioned acoustic suspension mid-bass section with a co-axially horn-loaded midrange and high frequency section through its center.
  • Transducer low frequency: 4 x 18" diameter neodymium motor woofers with 4" voice coils, waterproof cones transducer mid frequency 18" diameter neodymium motor bass driver with 4” voice coil
  • Transducer high frequency: co-axial compression driver featuring a 4" diameter ring diaphragm midrange and a co-axially positioned 2.5” voice coil ring diaphragm tweeter exiting via a 2” (51mm) throat horn mounted through the center of the 18” woofer pole piece.
  • Frequency response: (±3 dB) 25 - 19,000Hz
  • Maximum sustained output: 142 dB @ 1m (half-space)
  • Amplification: 7500W Class D: 5000W LF, 1600W MLF, 600W MHF, 300W HF
  • Processing: Integrated comprehensive DSP. 96kHz sampling rate with 8 pushbutton presets. All presets include high pass filters, low pass filters, phase alignment, equalization and multi-stage limiting. Storage capacity for up to 100 presets
  • Current draw 240V: 7A (nominal)
  • Net weight: 213 kg
I don't think it will fit in Amir's Klippel. Have to resort to other approaches to get the spin o rama data. :)
I'd like to set up an Atmos system with it.
Sort of dishonest naming however. The Krakatoa volcanic eruption produced approximately 180 db sound levels 100 miles away.
18" midbass
https://www.parts-express.com/B-C-1...pFLAa-f5EF9-mAcXst5pYf4qdtCbcI0mpZQ4Z2eJgaC0V, $1 078,13 or https://en.toutlehautparleur.com/triaxial-speaker-b-c-speakers-18htx100-8-8-8-ohm-18-inch.html, €901 - quite affordable driver for DIYing desktop speakers. And add a sub(s) under the table.
If one does not have such a large table, two small tables can be used.
Compact 20"x20"x12" box, gray - ported:
Any soap opera is a brain washing machine ;)
brain soap)) And the washing machine can be anything from a small old TV to a 17.9.11 home theater, for example, based on large Wilsons Krakatoas
