mwmkravchenko
Using the spider/damper as the "brake" is what I learned to do from the outset. The surround should allow travel unimpeded over the drivers desired travel. You end up with lower distortion this way. I tend to design long throw drivers that are not readily available off the shelf. At times that means some attention to the surround profile to mitigate unwanted midrange reflections.I strongly agree. At one time Dr. Klippel was of the opinion that the surround should be the displacement limiting component. I disagreed then and I disagree now. In a robust low frequency transducer design the spider(s) should be the limiting component. The surround should not be allowed to pull tight. This is primarily related to reliability. Surround lift is a common failure mode.
Cms(x)/Kms(x) vary with position but they do not vary directly with current, i (A). Motor force varies with both position and current, F(x) = iBl(x) N. So in the limit, as
iBl >> xKms(x) N and x > Xmax, then we are looking at an unstable system. The red curve below is effectively constant! Perhaps I should have said Cms(x) better limit displacement or else! Without additional information, one must consider such a system potentially unstable.
Was Anton S attempting to bait me with his cryptic question? So is that a "good" Bl(x) curve?
Working with a quality spider vendor helps in achieving the mechanical limits. And good motor design stops any self destruction.
