Aswell as objectively good means nothing if subjectively bad. Kef R3 or UD501 are good examples of objective and subjective quality. Alas, there's a lot of things to say about the discrepancy between perception and measurements, so my method is to make a short list based on objective measurements than pick smth from the list based on listening sessions.HI!
Don't trust What Hifi reviews, it's all subjectivist stuff, no measurements. Check out more serious sites as this one or
Stereophile. Subjective test mean nothing without scientific measurements to compare with.
... As well as US stuff is promoted in the US or UK stuff in UK . At least, it's not chinese . BTW, the report is about the old model. The new one seems better although I still find the radiators rather tiny for 100W. For the record, I live in France and didn't hear about any safety issue with Atoll stuffHI!
Forget about Atoll amps, they're badly built and probably dangerous! Check out this French report from a repairer, who is not tongued-tie:
https://hifirep.jimdofree.com/amplificateur-atoll-in100/
In France, Atoll amps are well promoted, probably because... They are made in France lol
Do you use the HA501 as a preamp ? it makes only 300mV, which is on the low side to drive decently a Hypex or Purifi module, even with the 25dB gain.I had same amp setup than you(Teac 501 series, all of them) but with Paradigm Prestige 85F.
I went to Audiophonics Hypex nc400 based one(1500 euros) a year ago , and IMHO, got a small improvement, with tighter bass and less distortion at very high volume(lot of power reserve, check out Amirm's test) . Now, you can get an Audiophonics purifi one for exactly same price, so get it! . HA-501 is a good headphones amp, with lot of Umph and power, but not as transparent as recent and cheaper ones, probably same thing as a preamp(Amirm tested IT, ).
For the record, I also have the PD player, all high WAF stuff.
And yes, I'm studying Audiophonic's offer (it's a french company it seems ).
