I’m assuming Erin has the LP-8 v2 (based on his photo)
It’s the LP-6v2
It’s the LP-6v2
www.audiosciencereview.com
So a direct Klippel measurement comparison with Amir's review of the LP-6v1:
Kali LP-6 Review: Studio Monitor
This is a review and detailed measurements of the Kali Audio LP-6 powered monitor (speaker). I purchased it for testing I think back in February or March. There has been a lot of requests to test it so I thought I do it before the year is over! The LP-6 costs US $149 on Amazon including Prime...www.audiosciencereview.com
It looks like they cleaned up the midrange substantially. But 2-13khz looks shelved down too much by like 2dB, that is strange.
Erin shared the teaser of his upcoming review of the LP-6v2:
Took a screenshot.
In comparison, here's LP-6v1:
I'm most interested to see how it compares to the JBL 308p.
Do you have the lp8 and lp6 v 2?I can't speak to the 308p but I can tell you the LP-6v2 is a much better buy than the 305p if for no other reason than the 305p is susceptible to internal resonance at the baffle (something that many besides myself have complained about). But the 305p is also cheaper.
I compared the two recently (like a couple days ago) - the Kalis sound much better.I can't speak to the 308p but I can tell you the LP-6v2 is a much better buy than the 305p if for no other reason than the 305p is susceptible to internal resonance at the baffle (something that many besides myself have complained about). But the 305p is also cheaper.
I'm not sure if i understand Amir and Erins rating correct, but the LP6 is alrdy rated highly (score of 5,2). If this fixed the hiss, does that mean for nearfield mixing/mastering that this speaker is the best for its price in the budget class? Better than both adam t5v, jbl 305/306 line?
I mean next step up is the Neumann kh80, genelec 8030c, dynaudio lyd 5, MTM and perhaps Kali In5. But in the "budget" price range will this officially be the best option?
Asking since i'm not sure about the ratings and the review system.
The preference score (and PIR) are meant for relatively untreated rooms listening midfield or farther. In a room with heavily reduced early reflections and listening nearfield (as studio monitors like these are intended) the LW response becomes considerably more important.I believe that the preference score is influenced highly by horizontal dispersion and is specifically for far field use, whereas Amir evaluate small monitors in near field, as they were designed to be used and where hiss will be more audible. I personally have seen very little correlation between preference score and general SUBJECTIVE preference in near field use.
Great. Question is now: lp-6 vs in-5 v2. The IN-8 v2 is much closer in pricepount and should be the pick over lp-8. But then lp-6 vs in-5 hmm...Erin posted his review. Not sure if a new thread needs to be started or not.
Based on the review, it looks to be a really good speaker.
Kali Audio LP-6v2 (Second Wave) 2-Way Studio Monitor Review
Kali Audio LP-6v2 2-Way Studio Monitor Reviewwww.erinsaudiocorner.com
