I think it really depends what you're looking for. The Element II is a great desktop all-in-one unit, but it's not the absolute pinnacle of performance (which isn't really as important as people make it out to be). What matters most is that you get something audibly transparent, with the specific features you need (ins and outs you need, available power for your headphones, whether you need a preamp out for powered monitors, bluetooth, etc.) with the level of reliability and/or customer support that works for you, and of course within your budget. JDS is fantastic on the support side (better than anyone in this price range, without question), and the reliability seems to be quite good; my JDS Atom Amp has held up quite well despite the lightweight build. But you can certainly get more flexibility and even technically better performance at a lower price, whether that's by going with an Atom Amp & DAC or any of the other popular budget stacks. All are cheaper than the Element II; honestly the most distinguishing features of the Element are the sharp industrial design (it's a beautiful chunk of carved metal with a glorious knob) and the top notch customer service. But you're paying quite a bit more for that fancy case than you would if you just want functionality and features.
If you're considering the BTR5, I'd just suggest you take a long hard look at the Qudelix 5k, which (IMO) has an even better feature set for the same price. Mine has been fantastic, to the point where I now use it as a dedicated USB DAC feeding my Atom Amp, and I have access to the same exact EQ profiles for all my headphones whether I'm at my desktop, out on the town, watching TV via bluetooth... Besides the headphones themselves, using EQ properly will make the biggest difference in your listening experience, and I love the way the Qudelix app integrates these features into an exquisitely designed app.
My recommendation is to get a JDS Atom Amp (assuming you can live with the lightweight plastic build), get the Qudelix 5K to use as a dedicated USB DAC and as a bluetooth device for portable use, and just get a normal non-fancy balanced cable for much less money. You'll get zero sonic improvement from a Hart cable, even if it's built well and looks nice. If you really want a dedicated standalone DAC, grab the Atom DAC and be done with it. Good luck!
