A
Wherein our friend Zeos muses in the Zeos way about why he prefers the Studio 570 over the "better" speaker from Triangle.
I have to say I'm struggling with a similar phenomenon in swapping between my 530 (with 2 subs, EQ) vs the A170 and the M106. Measured limitations notwithstanding there's an subjective appeal to the 530, especially off axis which is how I often listen, that I'm not yet finding with the other two.
We have commiserated about the 530's before.
I can say again that I picked them over my Revel m105's and sold the m105's with no regrets.
My A130's have a great sound as I mentioned already a few times over in other threads but I am about finished testing and experimenting with them and I don't plan to keep them. They are fantastic speakers, will be spot on for many and yet not quite my personal jam long term.
Curious how they compare to the 590s. Several times now I've almost bought one of the tower versions on one of those silly 60% sales. I have the 530, but never heard the towers. Is it the same sound but deeper and louder?
I had the 580's and the 530's. Yes at least for the 580's they sound nearly identical with a very big sound. I did not keep the 580's because logistically using the 530's with dual/"stereo" bass woofers is a better fit for me.
Since I use "stereo" supplemental bass, I can cross the 530's around 125-150, this really helped clean them up at higher volumes both in subjective performance and measured HD testing.
As mentioned, my ears detect the slightest tinniness with the 530s but I like them.
Interesting that you get a tiny quality. I wonder what it could be? Waveguide affects? 3rd order and higher distortion is world class low, 2nd is present but since it is only an octave up would really would just slightly change the tone, likely making it ever so much warmer/richer. I think the tweeter is mylar, could be a "mylar" effect.
Personally I have never picked up any tininess from the speaker itself at all, nor any real nasal quality of something along that line. Could it be in the recordings? I have actually found them to be have one of the most easy to listen to loudly & nicely dynamic highs of any commercial monitor sized speakers I have owned. I really like the highs here.
That tweeter/waveguide combo is incredible for me and if listening loudly, is barely working up a sweat before the woofer gives up. (that is why I high pass to separate bass drivers at around 125/150, making a 3-way. Then that 5.25" is able to go on quite a clean ride for higher outputs)
As an aside. Obviously JBL uses that 530 tweeter in the bigger, louder playing 570,580,590 and they also use it with a different waveguide in the newer EON PA line. Those handle 125db+ SPL levels. I really wonder if the signature of the sound in those PA speakers is similar to the studio line. Could be completely different - I mean they are PA speakers- but I might have to try a pair of the 10" models. On a certain level they are just big powered monitors, could be weirdly HIFI.
