oh yeahErin's review is up: https://www.erinsaudiocorner.com/loudspeakers/jbl_stage_a130/
My Top Ten Speakers Regardless of Price
cheapaudioman
Emotiva Airmotiv B1+
he is agree with Erin's review
The golfing panther I believe was with EQ, otherwise it was just ok. Did you use any EQ?Bought it because of the golfing panther, hated it when I got it. Erin's measurements confirmed what I heard, lean and thin. Some will defend the a130 till kingdom come, I hated it with a passion.
Now that second measurements are here. You were absolutely right the mid peak is from cabinet.
Don't understand how to compare distortion from both (Amir's and Erin's) though.
Thanks again and regards.
Or you can just buy a Quadelix 5K for a 100$ or so and have a USB DAC and Pre-amp capable of 10 PEQ filters, saving time and money.I wonder whether there is a way for the user to damp these cabinet resonances from the outside. Perhaps affixing some kind of pad against the sides. E.g. take something like a BBC-like bituminous pad and tie it in place with thick string. Or better, use flexible caulk to glue it in place. I would imagine you would not need to cover more than the central 15-25% of the side. The disadvantage is that this would be one try and hope it is not an error.
I have a pair of these I'm not using that I think are like the speaker that Amir measured. The reason I say that is mine seem to have the resonance just above 200Hz that does not show up in Erin's impedance and distortion measurements. I would be happy to send one or both of these down if @hardisj wants to investigate what is different. I'm guessing you can't afford to spend too much more time on this though.
I did the resistor tweak on these but I can short it out before sending.
I do think there is something different, whether it is QC or a design change. There is that resonance just above 200Hz that I mentioned. Compare Amir's and Erin' 86dB distortion curves, and see the kink there in Amir's impedance curve.it's very difficult to say the difference in the bass is because of Quality control. my measurements of my unit (Purchased in March/Feb last year) perfectly aligns with Erin's measurements. this post here
If you don't have a 10 PEQ EQ capable device don't bother honestly. but that doesn't necessarily mean the Wharfdale are any better.Very very tempted with a pair or two of these - only slight thing putting me off is the Wharfedale 220s are half the price they are on offer atm at £99 a pair !
I removed my guard before Erin purchased his machine. I did not fully remove all of the adjustments however and instead used absorption to get rid of a bit of reflection that was remaining: https://www.audiosciencereview.com/...o-corner-gets-a-klippel-nfs.19445/post-673175(With Erin's being more accurate in the highs because he removed the microphone's guard).
So please don't spread misinformation like this.
My quick read of the measurement difference is that it could be explained with stronger roll off of the woofer. If you look, Erin's measurements show less of the resonant peaks between 1 and 3 kHz as well. That is before the crossover frequency. Higher end speakers are factory tested and matched to 0.5 dB. Something like these mass market ones likely have much more relaxed criteria so crossover filters could very well be different between units. Short of testing the same unit, it is not possible to figure out more than we have.I'm sorry I didn't mean to offend in anyway, your measurements usually align very very well (Which says a lot about the accuracy of the NFS), it's just that for this particular speaker it's a little bit of a pickle.
I think it was the cabinet, though. I happened to try these on sorbothane hemishpheres and then the 220ish problem was amplified to the point that the speakers were really terrible (they were much better blu-tacked to stands). So pretty sure not to do with the room.One thing to keep in mind: you cannot compare anechoic distortion measurements against non-anechoic distortion measurements. The room is a big influence on the sound. A reflection is essentially harmonic distortion. Unless you are in the near field with no room influence, distortion measurements can be skewed easily by the room environment. Also, distance can effect the distortion profile due to proper summation of all drivers in loudspeakers. I don’t know how yours were performed but just making sure you are aware of this.
My measurements for harmonic distortion are performed using Klippel’s ISC module and are therefore anechoic.
In-Situ Compensation (ISC)
www.klippel.de
That's really interesting - you sent the resonances through the stands to the floor rather than leaving the speaker to its own devices.I think it was the cabinet, though. I happened to try these on sorbothane hemishpheres and then the 220ish problem was amplified to the point that the speakers were really terrible (they were much better blu-tacked to stands). So pretty sure not to do with the room.
