solderdude
Yes that will help a bit. The problem is the bias voltage and AC voltage limit which can only apply a limited amount of force depending on the air gap.
For lower frequencies a larger excursion is needed which lowers the efficiency of the driver but could increase the bias voltage.
So there is a fine line between bias voltage, AC voltage, stator distance and noise/crackling and 'sticking'.
For that reason electrostats are much more limited planar magnetics.
Hifiman now also has very thing membranes with very thin metal traces on it and enough magnetic force and air gap electrostatic HP's can not achieve.
