Archimago
Hi guys and gals, just wanted to invite folks here to a new test to try out in early 2020! It's based on Paul K's Distort software.
You know that measurements of audio gear typically will include harmonic distortion tests. We see numbers like 1% THD, 0.1% THD+N, etc... all the time. Typically also included with graphs in DAC, amp, preamp, phono cartridge results.
But what does this mean when it comes to listening and with real music?
Here's an opportunity to try for yourself and let me know what you hear - preferably using the best sound system you have! As usual, the results will be collected, analyzed, and published once the data gather is done by the end of April 2020. Plenty of time to listen and let me know what you hear.
Remember that I have used rather high amounts of distortion in some of these samples... Theoretically, this should be nowhere as difficult as "can you hear 16-bit vs. 24-bit?" or "24/96 vs. 16/44.1" tests.
Test: Is high Harmonic Distortion in music audible?
Thanks in advance...
