- Joined
- Jan 7, 2020
- Messages
- 950
- Likes
- 1,265
When I first went down the road of a PC/multichnnel dac active system - rule number 1 was do not connect tweeters to channels 1/2!
Channel mapping/routing in Audiolense is really easy. Under speaker setup you set it / label it however you are wired up. You can then safely test before running sweeps. Then the.cfg files are automatically generated using the same channel mapping. I dont get how you can get a wrong setup in the .cfg file??
