ifi iPurifier3 USB Filter Review
Rate this USB Filter/Tweak:
    Votes: 63 40.1%
    Votes: 61 38.9%
    Votes: 16 10.2%
    Votes: 17 10.8%
What they won't measure are issues orthogonal to the device under test. Noise over USB ground will travel on the RCA output and potentially cause audible problems. Switch DACs is not going to help you except randomly.
If the DAC is designed badly.
if it has proper isolation Noise over USB ground will not travel to the RCA or XLR output
On the other hand if dose not has any "isolation" and Noise over USB ground Would travel to the RCA output it would also go to the XLR outputs.
In this Cases your only suppressing the noise by the CMRR of the reviving device.
This is why i say CMRR of the reviving device shuld be tested as well as it shuld be tested if/how mush Noise over USB ground Would travel to the RCA output.
Since Noise on the USB ground is normal.
if it has proper isolation Noise over USB ground will not travel to the RCA or XLR OUTPUT.
Major effort is put in high performance DACs to provide such noise isolation. With RCA you couple the two devices and subject yourself to ground loops regardless of what is going on with USB. Only XLR avoids this and with it obviate the need for USB ground isolation.
Not in all of them... this is why it would be nice to test this...
With XLR you do the same thing...
The same ground loop common mode currents would go trough the XLR cable since they also connect ground of the reviving and transmitting device.
In this Cases your only suppressing the noise by the CMRR of the reviving device. This is why i say CMRR of the reviving device shuld be tested
So XLR is not automatically obviate this its only suppressing the effect.
Beaus do to the differential signal of the XLR connection the common mode part can be partially rejected.
How good an how mush of it still depends on the CMRR of the of the reviving device. (and other things like DACs output impedance matching and symmetry)
Why and how shuld i trust the AMP to filter out the CM part of the signal that shuld not be coming from the DAC (USB) in the first place.
I am not going to chase non problems. You were supposed to provide tests to demonstrate these points some three years ago. You asked for two weeks yet here we are.
The most common threads about noise for many years across the forums is strangely not about complex set ups and systems but the simple PC>DAC>active monitors.
Many times if not the most,with balanced connections.
And that 4-5 USB hi-speed chips found in most of the implementations usually works.
I don't know what this iFi contains,the new ones though do as they promise,up to any rate.
You kind of do.
DACs are a solved problems for the scope of your tests.
You can get ~100€ device that is audible transparent (within the scope of your tests).
So i would say you chase non problems
And you ignore the ones that regularly come up here like:
Amir and others have repeatedly stated that a well-designed DAC will already filter power/be galvanically isolated, and devices like the Purifier and others are not necessary. Considering that the M500 MkIII received a glowing recommendation, it seems reasonable to assume that it too falls under the category of "well-designed DACs", but there seems to nonetheless still be potential for noise issues,
It might be not so common problem. but whats never a problem is okay DAC "sounding" bad.
I've also had the same problem as Ian, using a Topping D70 Pro and A70 Pro stack (Running short balanced cables), connected to a Desktop with an RTX 4090 GPU. I hear a ton of noise coming from the USB input at higher output levels. I have to turn the volume high enough on the A70 Pro to even hear it, which is not a problem with most music, etc... but for some content like movies, it's definitely a noticeable issue. The issue is worse if, for example, I scroll through a webpage, you can hear the noise from the GPU through the headphones very audibly and it seeps into lower volumes. I would not be surprised if it's also an issue with gaming. Flipping the "Ground Lift" switch on the A70 completely eliminates it, though that is not a common feature.
If I ever have time to record and test it and show it, I will.... but for other's I personally do not think it's true that all dacs deemed "audibly perfect" on this website actually are... I also own a bifrost 2 with its galvanically isolated USB input and it has no such issues. Maybe if you get a power cable and rip the ground pin off the end, that might work as well, but your amp will no longer be grounded.
EDIT: Haha .. sorry, i misinterpreted the measurements initially. this obviously does not change my verdict and the line of argumentation here, but i will of course delete the faulty referenced passages below ..
The fact that a DAC incorporates internal filtering mechanisms does not necessarily imply that filtering applied upstream of those stages is functionally equivalent or redundant.
A useful analogy would be the treatment of DC artefacts in the mains supply. While a galvanic isolation transformer cannot pass DC by definition, it does not follow that DC-related artefacts upstream are entirely irrelevant. In practice, introducing a dedicated DC-blocking stage ahead of the isolation transformer in my own system resulted in a clearly different—and not merely subtle—sonic outcome. This suggests that artefacts which are theoretically blocked can still influence operating conditions, magnetic behaviour, or downstream interactions in non-trivial ways. As always, system and room dependence applies.
For those interested in system optimization, I would therefore encourage simply trying the device in their own setup, for me it has a significant acoustic improvement in terms of reducing microtemporal noise, which manifests in different ways across the whole spectrum. It may account specifically for a small portion of what is often referred to as the “night effect”, i.e. the observation that music can sound subjectively better during night-time hours (at least here in Germany, including smaller cities).
It is important to clarify that devices such as the iPurifier do not and cannot address all underlying mechanisms associated with the night effect. Large-scale contributors—such as reduced mains distortion, lower grid load asymmetry, or generally quieter electromagnetic environments—are clearly outside the scope of USB-side conditioning.
However, a smaller but potentially relevant subset of the night effect can plausibly be addressed. In particular, the iPurifier targets USB-related high-frequency noise, common-mode interference, and signal-integrity issues at the physical layer. These mechanisms are known to be influenced indirectly by system activity, RF traffic, and switching noise, all of which tend to be reduced during night-time conditions.
From a conservative standpoint, it therefore seems reasonable to assume that such a device may account for a limited fraction of the perceived night effect—perhaps on the order of a few percent up to around ten percent—by reducing HF noise and masking artifacts that persist even in otherwise well-optimized systems. This does not replicate the night effect as a whole, but may slightly narrow the gap between typical daytime and night-time listening conditions.
Finally, it is worth noting why such effects may be more readily observable in laptop-based playback chains. Laptops integrate high-speed CPUs, switching regulators, wireless transceivers (Wi-Fi, Bluetooth), and densely packed digital subsystems operating within a shared ground and power distribution network. Even when running on battery power, these subsystems generate broadband high-frequency noise and transient current activity that can couple into the USB interface at the physical layer.
While modern asynchronous USB DACs are highly effective at isolating audio clocking from host timing, they are not fully isolated from host-generated common-mode noise, ground modulation, or PHY-level signal-integrity issues. As a result, residual high-frequency artifacts originating from the laptop environment can still influence reference stability, analogue stages, and noise shaping within the DAC.
In this context, a device that specifically targets USB-side high-frequency noise, impedance balance, and common-mode interference may have a more clearly audible effect than in systems where the source is electrically simpler or already externally isolated. This does not imply a deficiency of the DAC or the USB protocol itself, but rather reflects the inherent complexity of modern laptop platforms and their electromagnetic operating environment.
I hope this helps to add some additional nuance to the discussion. The measurements themselves appear sound; my main point is that the conclusions drawn from them may benefit from a slightly less binary interpretation.
Thanks Amir for sharing these measurements.
If I may offer an alternative interpretation of the results in conjunction with my own listening observations:
With regard to the measurements discussed here, they show a distinct reduction of noise components above approximately 2 kHz. This frequency region is psychoacoustically relevant, for example with respect to second-order harmonic components and their influence on voice reproduction and transient clarity.
In my own listening, I perceived subtle yet fundamental reductions of high-frequency noise and masking effects across the spectrum, which is consistent with the observed changes and therefore not unexpected.
For those interested in system optimization, I would therefore encourage simply trying the device in their own setup. It may account for a small portion of what is often referred to as the “night effect”, i.e. the observation that music can sound subjectively better during night-time hours (at least here in Germany, including smaller cities).
ok
