Smsl po 100pro?
Laky66
Question: Does it make sense to use the SMSL PO100 Pro between iFi Zen Stream and Musician Pegasus R2R DAC?
Hi everyone,
I'm considering adding the SMSL PO100 Pro (DDC) between my iFi Zen Stream and Musician Pegasus R2R DAC, mainly to take advantage of the DAC's I2S input.
From a technical and measurable standpoint, I'm wondering if this setup is beneficial:
Can a DDC like the PO100 Pro reduce jitter or electrical noise compared to direct USB output from the Zen Stream?
Is there any measurable improvement (THD, SINAD, IMD, etc.) at the DAC's output when using I2S instead of USB?
Does it make sense to add a DDC like this when I already have a decent streamer like the Zen Stream?
Thanks in advance for any insights, measurements, or data. I'm not looking for subjective impressions — I'm more interested in objective facts about whether the DAC's output can be measurably improved using I2S via a DDC instead of USB.
The PO100 Pro cannot reduce jitter, as the best possible jitter will be achieved using asynchronous USB.
If your current setup suffers from ground loop induced noise, then switching to Zen Stream->PO100->Optical->Pegasus R2R would remove that noise.
Hi everyone,
I'll give you a very simple fact.
The Musician Pegasus R2R DAC converts the USB signal internally to I2S.
The PO100 Pro converts the USB signal to I2S, which you then feed into your Musician Pegasus R2R DAC.
The DAC developers would have done a very poor job if this resulted in an improvement.
DAC manufacturers today make great efforts to reduce jitter via USB and SPDIF/AES. I2S is usually not further considered or processed in the DAC (no jitter reduction) and is sent directly to the D/A converter.
The PO100 Pro had worse measured values via I2S with an SMSL DO400 than the DO400 directly via USB. Both use the same XMOS XU316 interface and convert the USB signal to I2S.
Perhaps you can draw some conclusions from this.
My system works perfectly. The sound is excellent—dynamic, with no audible distortion, noise, or other interference. Since I am an imperfect person, I long for perfection. And so, from time to time, I feel the urge to read various forums and reviews. Recently, I came across claims that using a digital interface, such as a Singxer F1, SMSL PO100 PRO... can noticeably improve the sound.
Those days are long gone. At some point, the improvements in DDCs trickled down to DACs. The technology is the same anyway: USB is converted to I2S, both in the DDC and the DAC. The components are also the same: XMOS, Amanero (ARM), Xing Audio, etc.
In this area, the Singxer F1 (obsolete), SMSL PO100 PRO, etc., are low-coast products that couldn't even improve a current DAC like the SMSL SU-1.
Maybe this will help anyone looking to buy a SMSL PO100pro
I got it to use with a RPI3B and my Musician Draco to test out I²S. Turns out, it didn't work with my RPi3B even after a fresh flash of Ropieee. It got stuck in trying to install drivers. Now, maybe the 100pro was in wrong UAC mode but everything installed on Rpi4 directly, which I am lucky to also have.
Then the Musician Draco was put in mode 4 and everything works nicely. The Draco is mqa capable, however, it doesn't seem to unfold properly with the 100pro. I don't care for MQA, just thought I mention it if it's an issue for anyone.
I don't think I can perceive any major sonic improvements, but it's a useful thing to own if needed for any other applications.
It certainly didn't degrade anything, however.
This MQA has been dead for a long time and Tidal has also abolished it.
Sure but there are still MQA-albums being sold, mainly in Asia. It's not completely dead. Doesn't matter, I don't care for it anyway
I was considering a PO100 to connect my Mac Mini to my Yamaha S301 internal DAC.
That's certainly a good solution.
However, the DAC in the Yamaha isn't that great based on the measured values. In the A-S701 test, it was even slightly worse than the amplifier itself, so it's actually a small bottleneck. It might not be directly audible yet, but it's at least close.
So you could consider investing a little more money and using an SMSL D1, SU-1, or PO100 AK as your DAC. Their measured values are very good, and the SINAD value alone is about 30 points higher than the Yamaha DAC.
Thanks good to know. Su-1 seems a good choice. cheers
Guys between SMSL SU-1 or SMSL P200, which one would you recommend.
What's important to you? I would NOT worry about sound quality since most DACs are better than human hearing.
...Personally, I don't need (or want) a stand-alone DAC. Everything I have that needs a DAC already has one built in.
The PS200 also has support for games consoles, for example, via UAC1 switching. Personally, I don't like plastic enclosures; I prefer the metal SU-1 enclosure.
Alternatively, you can also get the SMSL C100 and add Bluetooth to your A-S301. A bargain, considering the Yamaha YBA-11 starts at €99.00.
The C100 is an SU-1 with Bluetooth, a display, and a remote control.
And to confuse you and make your decision even more difficult, I personally prefer the D1 Rohm DAC, and the third one arrived yesterday. However, I also own an SU-1 and a C100.
In the end, you just buy the one that has the functionality you want and that you like.
Hi, I'm looking for a I2S cable matching MODE 1 configuration SMLS PO 100PRO. I want to connect my LAIV HARMONY DAC to it.
You only need a standard HDMI cable; anything else is a waste of money.
But with the LH DAC, you can skip that. The USB interface built into the LH DAC is superior to the PO100 Pro and is even galvanically isolated. Using i2s, you'll also be subject to the higher jitter of the PO100 Pro.
