Ideal solder diameter for through-hole soldering on a Khadas Tone Board?
Nobunaga
switzerland
Hey
i was wondering if 0.6 mm or 1.0 mm diameter of the solder wire would be better for through-hole soldering on a Khadas Tone Board?
Planning to solder a USB type-B connector on it
Cheers
  • 69119021_gold-plated-usb-female-type-b-20-plug(1).jpg.a8d6a0eaa73a32dc99cd52a0ebb481ab.jpg
Julf
Amsterdam, The Netherlands
For thorough-hole soldering, it is mostly a matter of preference and what you are used to. I do a fair bit of SMD, so tend to use smaller diameter.
PaulD
Other
For through hole work, I'd go 1mm at least. 0.6mm solder typically means that you are feeding more solder, that takes time, and you want to be fast (component hot time should be minimised)... Also, though hole soldering uses a lot more solder.
