Very interesting, use the subtitles for English
So you can't use two different headphones with different ohm right on the two headphone jacks (non independent) ? And if they have same ohm both will hear the same thing ? Will it have enough power to power both headphones ? Just need an adaptor for 1 of them correct to be able to plug it in ?
Also two or 3 reviews here ID4 :
https://www.thomann.de/gb/audient_id4_mkii_reviews.htm??ar=510532&page=1&order=0&rating=0&reviewlang[]=all
They claim :
Negative points:
- You only have 1 mic input.
- At maximum boost for your headset you will hear some noise
- Mic gain is good, unfortunately you cannot turn it to the maximum without noise.
- No mic mute button
- No headset mute button
Perfectly silent, no background noise except with maximum gain.
The cable supplied is a usb-c to usb-c but it can be used with a usb-c to usb-a cable, preferably usb3.
And on ID14 MKII : https://www.thomann.de/ro/audient_id14_mkii_reviews.htm??ar=510533&page=1&order=0&rating=0&reviewlang[]=all
Only regret, the USB C connection seems fragile to me ... and the metal frame of the card that I received was poorly closed ... Well, it's the time of COVID and the factories doing what they can, we forgive, but we must be careful.
I have a little problem with the headphone levels though. It's not loud enough for me to drive an open back DT-990. It's loud, really loud, but I want to go way past that if I'm mixing so that I don't have trouble hearing anything that is soloed but the mix level is low.
the huge problem is with the id audient software program, the handling of the software needs a lot of improvements .
The headphone outputs are loud and therefore high-impedance KH can be fired without any problems. (this is positive and contradicts the above)
The input and output sockets are unfortunately a bit wobbly or unstable and I have the feeling that there could be problems at some point.
The biggest point of criticism (and also the reason for the return) is the driver! Under Windows 10, there are cracks every now and then and the interface sporadically does not wake up from sleep mode of the PC (but USB connection is available).
Unfortunately, these circumstances force me to look around for a different interface, although I would have liked to keep the Audient because of its nice look and also because of the two headphone and monitor outputs.
Biggest drawback: Since March 15th (after Windows update to version 10.0.18363 Build 18363) the interface is no longer recognized sporadically. I'm still looking for a solution here. Maybe something is known about this from Thomann, the manufacturer or another user.
Now since Motu M2 is available in 5-7 weeks, i want to ask if ID4 or ID14 is good or better than Motu M2 ?
What about the video ? Any preference in tone and volume of different frequencies ? The M2 has more bass and less highs, the audient more highs and less bass. Motu is dark/night, Audient is day/light.
The ID4 has 1 input and is almost twice as cheeper as ID14. Actually i think the ID14 is a little bit too expensive compared to their single ID4.
